| [ATL] KM3 metamodel extension [message #57155] |
Thu, 09 August 2007 14:57  |
Originally posted by: zhangj.cis.uab.edu
I have a question for ATL/KM3. How to specify a km3 metamodel that extends
another km3 metamodel which is defined somewhere else? Do I need to set up
any path to guide the km3 parser to find the superclass?
Jing
| Re: [ATL] KM3 metamodel extension [message #57181 is a reply to message #57155] |
Thu, 09 August 2007 16:00  |
Originally posted by: marcos.didonet-del-fabro.univ-nantes.fr
You can use the generic editor, as if you were creating a complete KM3
metamodel. However, the editor will indicate syntax errors, since it
cannot refer to the extended elements.
We have a typical case of metamodel extension when using the AMW
plug-in. We define an extension like that:
class Attribute extends WLinkEnd {
The WLinkEnd class is defined in a core weaving metamodel. In this
particular case, it is not necessary to set up any path, because the
core metamodel is extended automatically when using the AMW tool.
Marcos.
Jing Zhang wrote:
> Hello,
> extends another km3 metamodel which is defined somewhere else? Do I need
> to set up any path to guide the km3 parser to find the superclass?
> Jing
FUDForum. Page generated in 0.04492 seconds
