| "Edit in SQL Query Builder..." does nothing [message #57154] |
Sun, 28 June 2009 19:21  |
on two different machines i installed Eclipse 3.5 and tried to test the
DTP. Connecting and Quering works fine. But when i try to open the "SQL
Query Builder" nothing happens. No error, no Logentry, just nothing.
Build id: 1.7.0.v20090611-1239
Details: I connect to a Database,
open a SQL Scrapbook,
type a query and run it,
everything works fine until now.
Now I mark the query and right click and select "Edit in SQL Query
Builder..." in the contextmenu.
I would expect a new tab with the Query Builder, but nothing happens.
regards,
Felix
| Re: "Edit in SQL Query Builder..." does nothing [message #436511 is a reply to message #57154] |
Thu, 30 July 2009 19:36  |
Hi Felix,
That combination works for me. The SQL Query Builder will open as a
dialog, not a new tab. Make sure the dialog is not covered up by the
main window.
Here's another thing to try:
1. Create a simple query such as "select * from myschema.customers"
using the SQL Scrapbook editor and save it in a .sql file, such as
"test1.sql" in a general project "project1". Close the SQL Scrapbook
editor.
2. Open a perspective or view where you can see the project, such as the
Project Explorer in the Resource perspective.
3. Right-click on the .sql file and do a Open With -> SQL Query Builder
action. This will open the query using the SQL Query Builder as an
editor rather than a dialog.
Fex Brown wrote:
> open a SQL Scrapbook, type a query and run it,
> regards,
> Felix
| Re: "Edit in SQL Query Builder..." does nothing [message #596180 is a reply to message #57154] |
Hi Felix,
main window.
editor.
Fex Brown wrote:
> regards,
> Felix
FUDForum. Page generated in 0.04790 seconds
