Home » Eclipse Projects » GEF » ContextMenu
ContextMenu [message #57068] Wed, 22 January 2003 11:39 Go to next message
I want to add actions to a ContextMenu that can only be determined at
runtime. The basic model is that I have an edit part that connects to other
edit parts. Once an edit part is added to a diagram I want to be able to
provide a list of objects that it is allowed to connect to and then
automatically add the object that the user selects. There are hundreds of
objects, but typically only one or two can connect. So what I want to
create is a sub-menu with these objects. e.g.
Add -> Object1
Object57
Object203
I can't see any obvious way I can achieve this using the ContextMenu as
provided. As it appears to require the Id for the Action when the action is
registered. Am I missing something or do I need to find another approach?
John.
Re: ContextMenu [message #57099 is a reply to message #57068] Wed, 22 January 2003 12:30 Go to previous message
In your ContextMenuProvider.buildContextMenu(IMenuManager), you can call getViewer().getContents()
to get the EditPart associated with the top-most model object. Then you can iterate through its
children and check to see if you can connect to any of them. If you find items you can connect to,
create a new Action and add it to the context menu. If you do this, the editor won't know about
these actions and won't be able to dispose of them. You should probably dispose of the action after
it runs.
Eric
> Add -> Object1
> Object57
> Object203
> John.
Previous Topic:Property change
Next Topic:The Command in GEF & EMF
Current Time: Fri Oct 31 03:29:45 EDT 2025
Powered by FUDForum. Page generated in 0.03787 seconds
