Home » Archived » BIRT » 1.0.1M1 question ?
1.0.1M1 question ? [message #57045] Tue, 12 July 2005 18:24 Go to next message
Is it eclipse 3.1 compatible ?
Haris Peco
Re: 1.0.1M1 question ? [message #58720 is a reply to message #57045] Fri, 15 July 2005 02:25 Go to previous messageGo to next message
Could you try with lastest stable build?
it's eclipse 3.1 compatible
Becuase GEF 3.1 has code breaking changes, current code can only support
eclipse3.1+GEF 3.0.x +EMF 2.1 now.
Wang Qiangsheng
"snpe" <snpe@snpe.co.yu> ??????:db18rp$b2r$1@news.eclipse.org...
> Thanks
> Haris Peco
Re: 1.0.1M1 question ? [message #58843 is a reply to message #58720] Fri, 15 July 2005 07:51 Go to previous messageGo to next message
I try 1.0.1M1 and cvs HEAD and I have problem with gef in with 2 classes
(LabelFigure and TextFlow)because changes in FlowBox
I try fix and it wokr, but I can't see label in desinger
I try example from site (customer table) and I create report fine,
but I see only empty rectangle in design mode (I don't see, for example
row['xxx'] in field or customername in column header
regards
> Thanks
> Wang Qiangsheng
>> Thanks
>> Haris Peco
Re: 1.0.1M1 question ? [message #59894 is a reply to message #58843] Tue, 19 July 2005 11:33 Go to previous messageGo to next message
For GEF 3.1 is not code compatible with GEF 3.0, we'are working on this
issue now. Current code only support eclipse 3.1 + GEF 3.0.x + EMF 2.1
Thank
Qiangsheng
"snpe" <snpe@snpe.co.yu> wrote in message
news:db80tt$pdt$1@news.eclipse.org...
> regards
> > Thanks
> > Wang Qiangsheng
> >> Thanks
> >> Haris Peco
Re: 1.0.1M1 question ? [message #60011 is a reply to message #59894] Tue, 19 July 2005 19:13 Go to previous messageGo to next message
Originally posted by: myname(with.between names).lombardisoftware.com
Any ETA on when Birt will be converted to GEF 3.1? Is this planed for
1.0.1M2?
Our application is at Eclipse 3.1/GEF 3.1 so Im anxious to start playing
with BIRT integration :)
Qiangsheng Wang wrote:
> Thank
> Qiangsheng
>> regards
>> > support eclipse3.1+GEF 3.0.x +EMF 2.1 now.
>> > Thanks
>> > Wang Qiangsheng
>> >> Thanks
>> >> Haris Peco
Re: 1.0.1M1 question ? [message #60512 is a reply to message #60011] Thu, 21 July 2005 05:10 Go to previous message
1.0.1 finial will support GEF 3.1
"Morten Moeller" <myname(with.between names)@lombardisoftware.com>
??????:dbk110$v2a$1@news.eclipse.org...
> 1.0.1M2?
>> Thank
>> Qiangsheng
>>> regards
>>> > Thanks
>>> > Wang Qiangsheng
>>> >> Thanks
>>> >> Haris Peco
Previous Topic:Problem In BIRT Report Layout View
Next Topic:Avoid pdf file
Current Time: Fri Nov 21 20:56:11 EST 2025
Powered by FUDForum. Page generated in 0.05417 seconds
