Home » Eclipse Projects » Mylyn » Configuring Mylyn context
Configuring Mylyn context [message #56971] Mon, 01 September 2008 07:03
Hi All,
I am trying to integrate Mylyn with a Eclipse based tool, and have
partially succeeded in the same. I would like to share a problem that I
faced and would be happy to get some suggestions/pointers.
At a particular instance, I work with a file(.di/diagram file) and the
other file(model) gets generated and updated dynamically behind the scene.
The di file gets added to the context of the currently activated task, as
expected, but the problem is that the model file(not needed to be
presented to the user) also gets added to the context. So on deactivation
and later on activation, all the files(along with the model files) gets
opened. So I would like to know the Mylyn API that I need to change to
filter our the model files and just restrict the context to the di files.
Thanks in advance.
Neeraj Bhusare.
Previous Topic:When I can use connector that connects with bugzilla 3.2 or higher version.
Next Topic:howto integrate Mylyn in RCP
Current Time: Tue Jul 08 17:46:31 EDT 2025
Powered by FUDForum. Page generated in 0.03883 seconds
