Home » Eclipse Projects » Plugin Development Environment (PDE) » Preference setValue problem
Preference setValue problem [message #56961] Sat, 18 April 2009 18:52 Go to next message
i have the problem that when i set two string values thw output is not the
same.
Here my code:
Preferences store = Activator.getDefault().getPluginPreferences();
store.setValue(PreferenceConstants.OAUTH_TOKEN, token.getToken());
System.out.println("A1:"+store.getString(PreferenceConstants.OAUTH_TOKEN));
store.setValue(PreferenceConstants.OAUTH_TOKENSECRET,token.g etTokenSecret());
System.out.println("B1:"+store.getString(PreferenceConstants.OAUTH_TOKENSECRET));
String a = store.getString(PreferenceConstants.OAUTH_TOKEN);
String b = store.getString(PreferenceConstants.OAUTH_TOKENSECRET);
System.out.println("A:"+a);
System.out.println("B:"+b);
The thing is that my output for A: and B: shows the same values not like
for A1: and B1:
Here the result:
A1: 2000-52566-36D555252352352523525
B1: vbXDDhhka67aRDk5fhPcDJ1j7dppxRR46777
A:vbXDDhhka67aRDk5fhPcDJ1j7dppxRR46777
B:vbXDDhhka67aRDk5fhPcDJ1j7dppxRR46777
what am i missing ...
Ivan
Re: Preference setValue problem [message #56987 is a reply to message #56961] Sun, 19 April 2009 00:44 Go to previous message
Papic Milan wrote:
> Hello,
> the same.
> Here my code:
> for A1: and B1:
> Here the result:
> what am i missing ... Regards
> Ivan
1. One possibility is that PreferenceConstants.OAUTH_TOKEN and PreferenceConstants.OAUTH_TOKENSCERT
constants refer to same string.
2. Whats your eclipse verion? Preferences has been deprecated and IEclipsePreferences is the new
recommended way to manage the preferences.
hth,
Ankur..
Re: Preference setValue problem [message #595857 is a reply to message #56961] Sun, 19 April 2009 00:44 Go to previous message
Papic Milan wrote:
> Hello,
> the same.
> Here my code:
> for A1: and B1:
> Here the result:
> Ivan
hth,
Ankur..
Previous Topic:Preference setValue problem
Next Topic:Problem with headless build on Eclipse 3.4.2
Current Time: Fri Nov 21 05:41:29 EST 2025
Powered by FUDForum. Page generated in 0.03226 seconds
