Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP crashes eclipse help
TPTP crashes eclipse help [message #56923] Thu, 09 March 2006 08:04 Go to next message
I verified this twice now (by adding/removing a link to the TPTP install
directory in eclipse's links subdirectory):
enabling TPTP causes eclipse's built-in help to fail.
To reproduce: just click Help => Help Contents.
The error message is:
Help can not be displayed. The embedded application server could not run
help web application. Check the log for details. [OK]
The corresponding entry in the log reads:
!ENTRY org.eclipse.tomcat 4 0 2006-03-09 14:03:20.436
!MESSAGE Exception occurred starting the embedded application server.
!STACK 0
org.apache.commons.logging.LogConfigurationException:
org.apache.commons.logging.LogConfigurationException: Class
org.apache.commons.logging.impl.Log4JLogger does not implement Log
org.apache.commons.logging.impl.LogFactoryImpl.newInstance(L ogFactoryImpl.java:532)
org.apache.commons.logging.impl.LogFactoryImpl.getInstance(L ogFactoryImpl.java:272)
at org.apache.commons.logging.LogFactory.getLog(LogFactory.java :414)
at org.apache.commons.digester.Digester.<init>(Digester.java:346)
org.apache.catalina.realm.MemoryRealm.getDigester(MemoryReal m.java:278)
at org.apache.catalina.realm.MemoryRealm.start(MemoryRealm.java :348)
org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1173)
org.apache.catalina.core.StandardEngine.start(StandardEngine .java:363)
at org.apache.catalina.startup.Embedded.addEngine(Embedded.java :464)
org.eclipse.tomcat.internal.TomcatAppServer.start(TomcatAppS erver.java:146)
org.eclipse.help.internal.appserver.AppserverPlugin.startWeb appServer(AppserverPlugin.java:143)
org.eclipse.help.internal.appserver.AppserverPlugin.getAppSe rver(AppserverPlugin.java:41)
org.eclipse.help.internal.appserver.WebappManager.start(Weba ppManager.java:58)
org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning(BaseHelpSystem.java:246)
org.eclipse.help.internal.base.HelpDisplay.displayHelpURL(He lpDisplay.java:164)
org.eclipse.help.internal.base.HelpDisplay.displayHelp(HelpD isplay.java:54)
org.eclipse.help.ui.internal.DefaultHelpUI.displayHelp(Defau ltHelpUI.java:122)
org.eclipse.ui.internal.help.WorkbenchHelpSystem.displayHelp (WorkbenchHelpSystem.java:822)
org.eclipse.ui.internal.actions.HelpContentsAction$1.run(Hel pContentsAction.java:83)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.actions.HelpContentsAction.run(HelpC ontentsAction.java:81)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:492 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:530)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:480)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:392)
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled
Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:925)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3287)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2907)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1899)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1863)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:417)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:99)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:85)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:58)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:60)
at java.lang.reflect.Method.invoke(Method.java:391)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: org.apache.commons.logging.LogConfigurationException:
org.apache.commons.logging.impl.LogFactoryImpl.getLogConstru ctor(LogFactoryImpl.java:416)
org.apache.commons.logging.impl.LogFactoryImpl.newInstance(L ogFactoryImpl.java:525)
... 47 more
Caused by: org.apache.commons.logging.LogConfigurationException: Class
org.apache.commons.logging.impl.LogFactoryImpl.getLogConstru ctor(LogFactoryImpl.java:412)
... 48 more
Hints / ideas / work-arounds?
Michael
Re: TPTP crashes eclipse help [message #57121 is a reply to message #56923] Thu, 09 March 2006 13:45 Go to previous messageGo to next message
As the prior message indicated, Help => Search worked... so I went and
tried Help => Help Contents... popped up fine. Difference between mine
and yours would be the links subdirectory, presumably... I think my TPTP
is installed in the default plugins location. I'd file a bugzilla, and
make sure to indicate the use of the links.
RDS
> !STACK 0
> at
> at
> at org.apache.catalina.realm.MemoryRealm.getDigester(MemoryReal m.java:278)
> at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1173)
> at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:363)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled
> Code))
> at
> at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 47 more
> at
> ... 48 more
> Michael
Re: TPTP crashes eclipse help [message #57335 is a reply to message #56923] Fri, 10 March 2006 11:17 Go to previous messageGo to next message
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 005971398525712D_=
Content-Type: text/plain; charset="US-ASCII"
Hi Michael,
This is not a TPTP problem. I was actually having this problem as well.
According to the Eclipse Project Release Notes this problem is caused by a
conflict between libraries in org.eclipse.tomcat and JARS that are
optionally installed in JRE, specifically in the jre/lib/ext directory. To
fix the problem, either start Eclipse with a clean JDK install or make
sure that the JRE used for running Eclipse doesn't contain any J2EE or
Apache jars in the jre/lib/ext directory.
I experience this problem when I use the IBM JDK , but it's fine with
Sun's JDK.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hi Michael,</font>
<br>
<br><font size=2 face="sans-serif">This is not &nbsp;a TPTP problem. &nbsp;I
was actually having this problem as well. &nbsp;According to the </font><font size=3><tt>Eclipse
Project Release Notes</tt></font><font size=2 face="sans-serif"> this problem
is caused by a conflict between libraries in org.eclipse.tomcat and JARS
that are optionally installed in JRE, specifically in the jre/lib/ext directory.
&nbsp;To fix the problem, either start Eclipse with a clean JDK install
or make sure that the JRE used for running Eclipse doesn't contain any
J2EE or Apache jars in the jre/lib/ext directory.</font>
<br>
<br><font size=2 face="sans-serif">I experience this problem when I use
the IBM JDK , but it's fine with Sun's JDK.</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 005971398525712D_=--
Re: TPTP crashes eclipse help [message #57486 is a reply to message #57335] Fri, 10 March 2006 17:46 Go to previous messageGo to next message
------=_NextPart_000_0024_01C6449C.E7F18570
charset="iso-8859-1"
Nope, I can't confirm this. It does NOT seem to depend on the JRE =
(alone).
I tried with 3 different JRE's (IBM 1.4.2, Sun 1.4.2, Sun 1.5.0) and it =
did not work with any of those.=20
I then re-installed an older eclipse (3.1.2) and with that it worked =
with ALL three JREs listed above.
From these few experiments I would rather conclude it's some eclipse =
version thing. To probe further I am right now re-installing a plain =
3.2.0M5a again and will try again from scratch and with ONLY TPTP and =
its prereqs installed and then adding misc. other plugins I am using and =
thereby hopefully being able to pinpoint the culprit. I'll keep you =
posted...
Michael
<Navid_Mehregani_nmehrega@ca.ibm.com> wrote in message =
news:dus8r3$b5h$1@utils.eclipse.org...
Hi Michael,=20
This is not a TPTP problem. I was actually having this problem as =
well. According to the Eclipse Project Release Notes this problem is =
caused by a conflict between libraries in org.eclipse.tomcat and JARS =
that are optionally installed in JRE, specifically in the jre/lib/ext =
directory. To fix the problem, either start Eclipse with a clean JDK =
install or make sure that the JRE used for running Eclipse doesn't =
contain any J2EE or Apache jars in the jre/lib/ext directory.=20
I experience this problem when I use the IBM JDK , but it's fine with =
Sun's JDK.=20
Navid Mehregani
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2802" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Nope, I can't confirm this. It does NOT =
seem to=20
depend on the JRE (alone).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>I tried with 3 different JRE's (IBM =
1.4.2, Sun=20
1.4.2, Sun 1.5.0) and it did not work with any of those. </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I then&nbsp;re-installed an older =
eclipse (3.1.2)=20
and with that it worked with ALL three JREs listed above.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>From these few experiments&nbsp;I would =
rather=20
conclude it's&nbsp;some eclipse version thing. To probe further I am =
right=20
now&nbsp;re-installing a plain 3.2.0M5a again and will try again from =
scratch=20
and with ONLY TPTP and its prereqs installed and then adding misc. other =
plugins=20
I am using and&nbsp;thereby hopefully being able to pinpoint the =
culprit.=20
</FONT><FONT face=3DArial size=3D2>I'll keep you posted...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Michael</FONT></DIV>
<DIV>&lt;<A=20
href=3D"mailto:Navid_Mehregani_nmehrega@ca.ibm.com">Navid_Mehregani_nmehr=
ega@ca.ibm.com</A>&gt;=20
wrote in message <A=20
href=3D"news:dus8r3$b5h$1@utils.eclipse.org">news:dus8r3$b5h$1@utils.ecli=
pse.org</A>...</DIV><BR><FONT=20
face=3Dsans-serif size=3D2>Hi Michael,</FONT> <BR><BR><FONT =
face=3Dsans-serif=20
size=3D2>This is not &nbsp;a TPTP problem. &nbsp;I was actually having =
this=20
problem as well. &nbsp;According to the </FONT><FONT =
size=3D3><TT>Eclipse Project=20
Release Notes</TT></FONT><FONT face=3Dsans-serif size=3D2> this problem =
is caused by=20
a conflict between libraries in org.eclipse.tomcat and JARS that are =
optionally=20
installed in JRE, specifically in the jre/lib/ext directory. &nbsp;To =
fix the=20
problem, either start Eclipse with a clean JDK install or make sure that =
the JRE=20
used for running Eclipse doesn't contain any J2EE or Apache jars in the=20
jre/lib/ext directory.</FONT> <BR><BR><FONT face=3Dsans-serif size=3D2>I =
experience=20
this problem when I use the IBM JDK , but it's fine with Sun's =
JDK.</FONT>=20
<BR><BR><FONT face=3Dsans-serif size=3D2>Navid =
Mehregani</FONT></BODY></HTML>
------=_NextPart_000_0024_01C6449C.E7F18570--
Re: TPTP crashes eclipse help [message #57511 is a reply to message #57486] Fri, 10 March 2006 18:17 Go to previous messageGo to next message
------=_NextPart_000_003A_01C644A1.2EC25930
As I already wrote: it's NOT the JRE!
I just installed another plain copy of eclipse 3.2.0M5 plus TPTP =
(tptp.runtime-TPTP-4.2.0-200602281515) and its prereqs =
(emf-sdo-SDK-2.1.0, xsd-SDK-2.1.0) onl and already that does not work. =
And that's with Sun JDK's...
On first search I would say the version conflict is between=20
eclipse's own =
....\eclipse\plugins\org.apache.ant_1.6.5\lib\ant-apache-log 4j.jar=20
and TPTP's =
....\eclipse\plugins\org.apache.jakarta_log4j_logging_1.2.8. v200602281515.=
jar
Michael
"Michael Moser" <mmo@zurich.ibm.com> wrote in message =
news:dusvm7$g5i$1@utils.eclipse.org...
(alone).
posted...
Michael
Hi Michael,=20
Sun's JDK.=20
Navid Mehregani
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>As I already wrote: </FONT><FONT =
face=3DArial=20
size=3D2>it's NOT the JRE!</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I just installed another plain copy of =
eclipse=20
3.2.0M5 plus TPTP (tptp.runtime-TPTP-4.2.0-200602281515) and its prereqs =
(emf-sdo-SDK-2.1.0, xsd-SDK-2.1.0) onl and already that&nbsp;does not =
work.=20
</FONT><FONT face=3DArial size=3D2><FONT face=3DArial size=3D2>And=20
that's&nbsp;with&nbsp;Sun JDK's...</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;</DIV></FONT>
<DIV><FONT face=3DArial size=3D2>On&nbsp;first search&nbsp;I would say =
the version=20
conflict is between </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>eclipse's own &nbsp;</FONT><FONT =
face=3DArial=20
size=3D2> ...\eclipse\plugins\org.apache.ant_1.6.5\lib\ant-apache-log4 j.ja=
r=20
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>and&nbsp;</FONT><FONT face=3DArial =
size=3D2>TPTP's=20
jar</FONT></DIV>
<DIV>"Michael Moser" &lt;<A=20
href=3D"mailto:mmo@zurich.ibm.com">mmo@zurich.ibm.com</A>&gt; wrote in =
message <A=20
href=3D"news:dusvm7$g5i$1@utils.eclipse.org">news:dusvm7$g5i$1@utils.ecli=
seem to=20
1.4.2, Sun=20
eclipse (3.1.2)=20
rather=20
right=20
scratch=20
plugins=20
culprit.=20
<DIV>&lt;<A=20
this=20
is caused by=20
optionally=20
fix the=20
the JRE=20
experience=20
JDK.</FONT>=20
<BR><BR><FONT face=3Dsans-serif size=3D2>Navid Mehregani</FONT> =
</BODY></HTML>
------=_NextPart_000_003A_01C644A1.2EC25930--
Re: TPTP crashes eclipse help [message #57690 is a reply to message #57511] Sun, 12 March 2006 19:06 Go to previous messageGo to next message
After responding to another message where the person was running Eclipse
3.2M5a with EMF/XSD/SDO 2.1, thinking those were the pre-reqs for TPTP
of 200602281515 (TPTP 4.2M5), I'm confused... where is this info coming
from? The info from the 200602281515 download page for TPTP says:
# Java runtime (JRE) or Java development kit (JDK) 1.4
# Eclipse SDK 3.2.0 M5a
# Eclipse Modeling Framework (EMF and XSD) SDK 2.2.0 M5
That's cut-and-pasted, with the newsreader changing the bullet to #.
Note that it is EMF/XSD 2.2.0 M5 ...
How come people keep saying they're running with 2.1.0 EMF/XSD? As I
said, I'm confused... and others appear to be as well!
RDS
> eclipse's own
> ...\eclipse\plugins\org.apache.ant_1.6.5\lib\ant-apache-log4 j.jar
> and TPTP's
> ...\eclipse\plugins\org.apache.jakarta_log4j_logging_1.2.8.v 200602281515.jar
> Michael
> "Michael Moser" <mmo@zurich.ibm.com <mailto:mmo@zurich.ibm.com>> wrote
> in message news:dusvm7$g5i$1@utils.eclipse.org...
> Nope, I can't confirm this. It does NOT seem to depend on the JRE (alone).
> and thereby hopefully being able to pinpoint the culprit. I'll keep you
> posted...
> Michael
> <mailto:Navid_Mehregani_nmehrega@ca.ibm.com>> wrote in message
> Hi Michael,
> Sun's JDK.
> Navid Mehregani
Re: TPTP crashes eclipse help [message #57739 is a reply to message #57690] Mon, 13 March 2006 03:01 Go to previous messageGo to next message
Just a guess trying to recap how I came up with this mix:
Probably by working through this article
http://www.eclipse.org/articles/Article-TPTP-Profiling-Tool/ tptpProfilingArticle.html
but already having 3.2.0M5 installed and noting that there is also a
newer 4.2 available for that eclipse version, but not scrolling down far
enough on the download page to also read the prereq's section for that
TPTP version.
But also downloading the newer EMF/XSD/SDO 2.2.0M5 version doesn't fix
the problem...
Michael
"Randy D. Smith" <randy.d.smith@intel.com> wrote in message
news:dv2d5f$9c7$1@utils.eclipse.org...
> Eclipse 3.2M5a with EMF/XSD/SDO 2.1, thinking those were the pre-reqs
> for TPTP of 200602281515 (TPTP 4.2M5), I'm confused... where is this
> info coming from? The info from the 200602281515 download page for
> TPTP says:
> RDS
>> work. And that's with Sun JDK's...
>> eclipse's own
>> and TPTP's
>> Michael
>> wrote in message news:dusvm7$g5i$1@utils.eclipse.org...
>> (alone).
>> you posted...
>> Michael
>> Hi Michael,
>> Sun's JDK.
>> Navid Mehregani
Re: TPTP crashes eclipse help [message #57953 is a reply to message #57121] Tue, 14 March 2006 08:44 Go to previous messageGo to next message
news:dupt4j$d8o$2@utils.eclipse.org...
> TPTP is installed in the default plugins location. I'd file a
> bugzilla, and make sure to indicate the use of the links.
Since working without documentation and no online help working was too
cumbersome I have bitten the bullet and installed TPTP directly into
eclipse's plugin directory and - surprise, surprise - this made the
online help working. So it's obviously a version conflict in the logging
between the eclipse base (3.2M5a) and TPTP-4.2.0-200602281515.
My assumption is, that installing TPTP directly into eclipse's plugin
folder overwrites some .jar of the base version and then both use the
same version and are happy, while having two different log4j jars
around, as is the case when using the links mechanism, surfaces this
version conflict.
I've filed a corresponding bugzilla since I *hate* to have to install
plugins directly into eclipse! If each plugin simply comes and
overwrites existing .jars in the eclipse-plugins directory this IMHO
creates a similar potential for problems and version conflicts as
Windows did with its DLL hell. These times should be history!
Michael
Re: TPTP crashes eclipse help [message #58051 is a reply to message #57953] Tue, 14 March 2006 10:21 Go to previous messageGo to next message
Agree on all points. Thanks for filing the bugzilla.
RDS
> version conflict.
> Michael
Re: TPTP crashes eclipse help [message #58350 is a reply to message #57739] Wed, 15 March 2006 03:13 Go to previous messageGo to next message
I am having the same problem.
I use eclipse3.2M5, OS = linux, sun-jre-1.5.0.06
with tptp:
http://www.eclipse.org/tptp/home/downloads/drops/TPTP-4.2.0- 200603140100.html
and emf-2.2.0-v200602241148
The problem occures only after installing the tptp plugins.
once again this is the exception :
org.eclipse.core.runtime.CoreException[0]:
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1074)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3158)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2838)
... 46 more
... 47 more
and following the exception:
... 46 more
... 47 more
Re: TPTP crashes eclipse help [message #58394 is a reply to message #58350] Wed, 15 March 2006 04:13 Go to previous messageGo to next message
I "solved" this by directly extracting TPTP into eclipse's folder. See
my yesterday's append (news:dv6hgj$lkd$1@utils.eclipse.org) on this (in
the same thread).
Michael
"kiril mitov" <kiril_mitov@abv.bg> wrote in message
news:3b7f50c83fccfec2e33318a3474a6684$1@www.eclipse.org...
Re: TPTP crashes eclipse help [message #58414 is a reply to message #58394] Wed, 15 March 2006 04:40 Go to previous messageGo to next message
My ecilpse directory is /home/kiril/local/eclipse
The tptp download is located in /home/kiril/down/eclipse
What I do is the following:
unzip /home/kiril/down/eclipse/tptp.sdk-TPTP-4.2.0-200603140100.zi p -d
/home/kiril/local/
Isnt this the right way to extract the archive...
Thanks...
Re: TPTP crashes eclipse help [message #58494 is a reply to message #58414] Wed, 15 March 2006 05:43 Go to previous messageGo to next message
I assume so (I am using windows' built-in extractor, so I can't really
comment on whether this is the correct command & option).
What I wanted to say is that I had to actually copy the TPTP stuff into
eclipse's subdirectories and not only link to it (a different mechanism
using which one can normally install plugins without polluting the
original eclipse installation. This allows to more easily upgrade
eclipse, remove plugins and/or change combinations of plugins if need
is).
With the latest TPTP this does not work because it obviously comes with
a different logging library version than what base eclipse is using and
those two then conflict, unless TPTP's installation/unzipping actually
overwrites eclipse's own version.
Michael
news:73913f64ded1726d88a732f631b1402b$1@www.eclipse.org...
> /home/kiril/local/
> Thanks...
Re: TPTP crashes eclipse help [message #58616 is a reply to message #58494] Wed, 15 March 2006 15:02 Go to previous messageGo to next message
It looks like kiril is extracting over ecilpse properly in his Linux
environment, and the EMF/XSD/SDO version is the right one for that
version of TPTP. But the original message from kiril mentioned Eclipse
3.2M5 ... again, the "M5" train requires Eclipse 3.2M5a <== NOTE THE
"a". I just checked the 4.2 TPTP download page, followed the link to the
Eclipse requirement, and verified that there was indeed an "a" version
for Linux... so make sure you're using THAT Eclipse.
RDS
> eclipse, remove plugins and/or change combinations of plugins if need is).
> Michael
>> /home/kiril/local/
>> Thanks...
Re: TPTP crashes eclipse help [message #59321 is a reply to message #58616] Mon, 20 March 2006 10:24 Go to previous messageGo to next message
I have downloaded eclipse 3.2M5a from
http://download.eclipse.org/eclipse/downloads/drops/S-3.2M5a -200602231656/index.php
But the exception still occures. A have again made a full new
installation. This are the commands as I have executed (in this order)
them in the shell:
# mkdir eclipse3.2M5a_64
# cd eclipse3.2M5a_64/
# tar -xzvf
/home/kiril/down/eclipse/eclipse-SDK-3.2M5a-linux-gtk-x86_64 .tar.gz
# unzip /home/kiril/down/eclipse/GEF-SDK-3.2M5.zip -d .
# unzip /home/kiril/down/eclipse/emf-sdo-xsd-SDK-2.2.0M5.zip -d .
# unzip /home/kiril/down/eclipse/tptp.sdk-TPTP-4.2.0-200603140100.zi p -d .
# cd eclipse/
# ./eclipse &
I have tried to install eclipse without unziping tptp.sdk and then there
is no such exception.
This is the session data for the exception:
eclipse.buildId=I20060223-1656
java.version=1.5.0_06
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
Althought the build is for x86_64 the same error occures on x86 that is
not 64
This again is the stack trace:
Message :
The embedded application server could not run help web application.
Exception Stack Trace:
... 46 more
... 47 more
In the Plug-in column in the error log for this exception is shown:
org.eclips.base.help
This exception is shown in the error log as a child of the previouse:
Message:
Exception occurred starting application server.
... 46 more
... 47 more
I dont have an idea why this is happening...
Hope you could help me...
Re: TPTP crashes eclipse help [message #66722 is a reply to message #56923] Fri, 14 April 2006 13:42 Go to previous messageGo to next message
--------------030507050101000303010505
I have just spent the last few hours beating my head against the
proverbial wall, sure do will I had read this thread sooner :'( My
circumstances, however, are slightly different and may help to figure
out what the real underlying problem is.
The plugin we are developing depends on common-logging.jar. All works
fine in Eclipse 3.1.x, but in 3.2.M5a with TPTP 4..2.0 we experience the
reported exception. At first I figured it was a versioning problem with
the commons-logging shipped in org.apache.jakarta_commons_logging_1.0.3
so I replaced ours with the one shipped by TPTP. Guess what? It still
caused the exception. If I remove my plugin help works fine, if I
remove only commons-logging.jar from my plugin help works fine, but of
course my plugin is broken. Of point of interest we do *not* export this
jars packages in the Manifest, which I thought was supposed to give us
the control over exactly this type of problem
Has a bug report been opened on this yet? If so a pointer to it would be
appreciated.
Joel
> install directory in eclipse's links subdirectory):
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Code))
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 47 more
> at
> ... 48 more
> Michael
<html>
<head>
</head>
<font face="Helvetica, Arial, sans-serif">Hi,<br>
<br>
proverbial wall, sure do will I had read this thread sooner <span
class="moz-smiley-s15"><span> :'(&nbsp;&nbsp; </span></span>&nbsp; My circumstances,
however, are slightly different and may help to figure out what the
real underlying problem is.<br>
<br>
the reported exception. At first I figured it was a versioning problem
with the commons-logging shipped in <font color="#3333ff">o</font><font
color="#3333ff">rg.apache.jakarta_commons_logging_1.0.3</font > so I
replaced ours with the one shipped by TPTP. Guess what? It still caused
the exception.&nbsp; If I remove my plugin help works fine, if I remove only
commons-logging.jar from my plugin help works fine, but of course my
plugin is broken. Of point of interest we do <b>not</b> export this
the control over exactly this type of problem<br>
<br>
be appreciated.<br>
<br>
Cheers,<br>
Joel<br>
<br>
<br>
</font><br>
<blockquote cite="middup968$r94$1@utils.eclipse.org" type="cite">I
<br>
<br>
<br>
To reproduce: just click Help =&gt; Help Contents.
<br>
<br>
<br>
run
<br>
help web application. Check the log for details.&nbsp;&nbsp; [OK]
<br>
<br>
<br>
<br>
<br>
<br>
<br>
!STACK 0
<br>
<br>
<br>
<br>
<br>
at org.apache.commons.digester.Digester.&lt;init&gt;(Di gester.java:346)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Code))
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
.... 47 more
<br>
<br>
<br>
.... 48 more
<br>
<br>
<br>
<br>
<br>
Michael
<br>
<br>
</blockquote>
</body>
</html>
--------------030507050101000303010505--
Re: TPTP crashes eclipse help [message #66743 is a reply to message #66722] Fri, 14 April 2006 17:04 Go to previous message
Joel Rosi-Schwartz wrote:
> appreciated.
All the dupes point to bugzilla_#132020 <
https://bugs.eclipse.org/bugs/show_bug.cgi?id=132020 > as "the
original", and it shows as fixed in 3.2M6.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Previous Topic:AGR - problems with view menus
Next Topic:how to profile java application on RAC
Current Time: Tue Jul 22 01:52:43 EDT 2025
Powered by FUDForum. Page generated in 0.34803 seconds
