| Perspective Article: Problems opening perspective [message #56686] |
Fri, 30 May 2003 16:15  |
Originally posted by: eipe.uiuc.edu
I was following the Perspective Article
( http://www.eclipse.org/articles/using-perspectives/Perspecti veArticle.html);
I've created the perspective, and when I re-start Eclipse, the 'Test'
perspective shows up. When I click on it to open it (Window -> Open
Perspective -> Other -> Test), I get a dialog box with the following
message:
Problems opening perspective: (org.eclipse.ui.articles.perspective.Test)
That doesn't seem to indicate any possible course of action.
Did anyone have a similar problem when they tried this?
Thanks in advance
Rohit Eipe
| Re: Perspective Article: Problems opening perspective [message #56875 is a reply to message #56822] |
Fri, 30 May 2003 17:26   |
Simon Arsenault wrote:
> Did you check the .log file for information why its failing?
> Simon :-)
> "Rohit Eipe" <eipe@uiuc.edu> wrote in message
> news:bb8fgs$ebi$1@rogue.oti.com...
> > Rohit Eipe wrote:
> > > Hi
> > > I\'ve created the perspective, and when I re-start Eclipse, the \'Test\'
> > > message:
> > > That doesn\'t seem to indicate any possible course of action.
> > > Thanks in advance
> > > Rohit Eipe
> > I figured out what the problem was (see above), but nothing happens when I
> > choose the Test Perspective, and click ok. I don't see a window like the
> > one depicted in the article.
> > If you followed the article and everything worked, could you supply a src
> > file that I can look at please?
> > Thanks
> > Rohit Eipe
I checked the .log file, and this is what is being appended to it
everytime I try to open the TestPerspective:
!ENTRY org.eclipse.ui 4 4 May 30, 2003 16:16:49.832
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 May 30, 2003 16:16:49.843
!MESSAGE java.lang.ClassCastException
!STACK 0
org.eclipse.ui.internal.registry.PerspectiveDescriptor.creat eFactory(PerspectiveDescriptor.java:93)
org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Pers pective.java:643)
org.eclipse.ui.internal.Perspective.createPresentation(Persp ective.java:277)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:176)
org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java:959)
org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(Wor kbenchPage.java:614)
at org.eclipse.ui.internal.WorkbenchPage.access$8(WorkbenchPage .java:606)
at org.eclipse.ui.internal.WorkbenchPage$11.run(WorkbenchPage.j ava:2670)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:65)
org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:2668)
org.eclipse.ui.internal.ChangeToPerspectiveMenu.run(ChangeTo PerspectiveMenu.java:52)
at org.eclipse.ui.actions.PerspectiveMenu.run(PerspectiveMenu.j ava:322)
org.eclipse.ui.actions.PerspectiveMenu.runOther(PerspectiveM enu.java:337)
org.eclipse.ui.actions.PerspectiveMenu$4.widgetSelected(Pers pectiveMenu.java:110)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:87)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:836)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1775)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1483)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1271)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1254)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
Any help is appreciated. Thanks.
Rohit
| Re: Perspective Article: Problems opening perspective [message #57063 is a reply to message #56875] |
Fri, 30 May 2003 19:47  |
> > Simon :-)
> > \"Rohit Eipe\" <eipe@uiuc.edu> wrote in message
> > > Rohit Eipe wrote:
> > > > Hi
> > > > I\\\'ve created the perspective, and when I re-start Eclipse, the
\\\'Test\\\'
> > > > message:
> > > > That doesn\\\'t seem to indicate any possible course of action.
> > > > Thanks in advance
> > > > Rohit Eipe
I
> > > choose the Test Perspective, and click ok. I don\'t see a window like the
> > > Thanks
> > > Rohit Eipe
> Hi
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Rohit
Never mind, I figured it out.
Rohit
FUDForum. Page generated in 0.05215 seconds
