Home » Archived » BIRT » Dynamic Font
Dynamic Font [message #56644] Tue, 12 July 2005 11:14 Go to next message
Is there a way to change the font of a portion of text based on parameter
values?
Re: Dynamic Font [message #56887 is a reply to message #56644] Tue, 12 July 2005 14:05 Go to previous messageGo to next message
Joe,
You can use a text item instead of a data/label item for your text.
Then, use the <value-of> tag in for text item. ROM text spec has
detailed info about the value-of tag.
Stanley Wang
BIRT Engine
> values?
Re: Dynamic Font [message #59169 is a reply to message #56887] Fri, 15 July 2005 13:12 Go to previous messageGo to next message
I've added a text item and i'm running into the following problem with the
value-of tag:
<I>
<VALUE-OF format="html">
var value;
value="test";
value;
</VALUE-OF>
</I>
gives the error:
There are errors on the report page:
Error1:Invalid Javascript expression: null
The expression cannot be null or empty
So then I went to the rom spec for an example and tried the following and
got the error below
<value-of format="html">
String value;
if ( 10.24 < 0 )
value = "<span style=\"red\"";
value += format( 10.24, "(##,###.##)" );
if ( 10.24 < 0 )
value += "</span>";
value;
</value-of>
Error1:Invalid Javascript expression: String value; if ( 10.24 < 0 ) value =
missing ; before statement
Anyone tried this?
"Stanley Wang" <swang@actuate.com> wrote in message
news:db10no$vg4$4@news.eclipse.org...
> Joe,
> You can use a text item instead of a data/label item for your text. Then,
> use the <value-of> tag in for text item. ROM text spec has detailed info
> Stanley Wang
> BIRT Engine
>> values?
Re: Dynamic Font [message #61664 is a reply to message #59169] Mon, 25 July 2005 09:55 Go to previous message
For all those interested...after much pain here's how to have 2 fonts based
on some condition:
<span style="font-family: ARIAL; font-size: 36;">
<VALUE-OF contentType="HTML">
var value='*'+row["value"]+'*';
if(barcodeFont=="ARIAL"){
value;
}else{
value="";
value;
</VALUE-OF>
</span>
<span style="font-family: COURIER; font-size: 36;">
if(font=="COURIER"){
value;
}else{
value="";
value;
</VALUE-OF>
</span>
"Joe Rybacki" <Joe.Rybacki@dynetics.com> wrote in message
news:db8qq9$opg$1@news.eclipse.org...
> value-of tag:
> <I>
> var value;
> value="test";
> value;
> </VALUE-OF>
> </I>
> gives the error:
> got the error below
> String value;
> if ( 10.24 < 0 )
> if ( 10.24 < 0 )
> value += "</span>";
> value;
> </value-of>
> Anyone tried this?
>> Joe,
>> Stanley Wang
>> BIRT Engine
>>> parameter values?
Previous Topic:formatting problems: an example of what i mean
Next Topic:using more than 2 data sets
Current Time: Mon Nov 17 04:24:08 EST 2025
Powered by FUDForum. Page generated in 0.17675 seconds
