| Re: incorrect xdebug launch url [message #56879 is a reply to message #56825] |
Thu, 04 October 2007 06:22  |
I though something like this might be the problem, but the "path" itself
was completely messed up (being prepended with my home directory).
However, as Dave suggested, I changed (Eclipse's) default browser to
Firefox, and tried launching the debugger again, and it worked.
Maybe there's some strange optimisation whereby the internal web browser
tries to read the file on the filesystem directly if it thinks it's
equivalent to the URL it's being asked to load??
Anyway, thanks for the help.
--M.
Jan Walter wrote:
> I think that is related to the Windows settings which programm is linked
> to .html files.
> I had the same problem that PDT opened my HTML-editor until i explicitly
> told eclipse which browser it should use.
> Dave schrieb:
>> Which web browser have you configured eclipse to use ?. You could try
>> changing it to firefox and see if that helps.
>> Apart from that I have never seen it do anything like that before. I
>> make a request to an eclipse API to open the URL for me.
>> Dave Kelsey
>> Michael Stillwell wrote:
>>> When I launch the xdebug remote debugger, notepad (!) pops up with the
>>> error message:
>>> "C:Documents and SettingsMichael
Stillwellhttp://ski.ms/simpletest/reservation.html?XDEBUG_SE SSION_START=ECLIPSE_DBGP&KEY=119143983189813"
>>> not found. Would you like to create this file?
>>> As one might imagine, the debugger does not work. If I enter the
>>> embedded URL into a web browser, XDebug operates as normal.
>>> I'm not using the "auto-generate" url function--I enter
>>> http://ski.ms/simpletest/reservation.html into the URL field but I end
>>> up with the error message described above.
>>> Is there some way to fix this?
>>> --M.
FUDForum. Page generated in 0.04975 seconds
