Home » Modeling » GMF (Graphical Modeling Framework) » IContentAssistProcessor
| IContentAssistProcessor [message #56601] |
Wed, 27 September 2006 16:23  |
Originally posted by: vcciubot.uwaterloo.ca
Following Michael Golubev's suggestion on a previous thread, I've created
a completion processor using the code below.
However, the method computeCompletionProposals doesn't get called. Other
methods such as getCompletionProposalAutoActivationCharacters get called.
There's also a pop up indicating content assist, but nothing happens when
pressing ctrl-space.
Any suggestions?
thanks in advance,
vlad
public class Bluenose2ContentAssistProcessor implements IContentAssistProcessor {
private static final ICompletionProposal[] NO_PROPOSALS= new ICompletionProposal[0];
private static final IContextInformation[] NO_CONTEXTS= new IContextInformation[0];
private char[] characters;
* list of possible values
private List values;
public Bluenose2ContentAssistProcessor(List values) {
this.values = values;
characters = new char[values.size()];
Iterator it = values.iterator();
int i = 0;
while (it.hasNext()) {
String value = (String) it.next();
characters[i] = value.charAt(0);
public ICompletionProposal[] computeCompletionProposals(ITextViewer viewer,
int offset) {
try {
String prefix= getPrefix(viewer, offset);
if (prefix == null || prefix.length() == 0)
return NO_PROPOSALS;
List suggestions= getSuggestions(prefix);
List result= new ArrayList();
for (Iterator it= suggestions.iterator(); it.hasNext();) {
String string= (String) it.next();
if (string.length() > 0)
result.add(createProposal(string, prefix, offset));
return (ICompletionProposal[]) result.toArray(new ICompletionProposal[result.size()]);
} catch (BadLocationException x) {
// ignore and return no proposals
private ICompletionProposal createProposal (String string, String prefix, int offset) {
//need to adjust these parameters
return new CompletionProposal(string, offset, string.length(), offset + string.length());
* @param prefix
* @return list of values beginning with <code>prefix</code>
private List getSuggestions(String prefix) {
List suggestions = new ArrayList();
if (value.startsWith(prefix))
suggestions.add(new String(value));
return suggestions;
* @param viewer
* @param offset
* @return the text input by the user
* @throws BadLocationException
private String getPrefix(ITextViewer viewer, int offset) throws BadLocationException {
IDocument doc= viewer.getDocument();
if (doc == null || offset > doc.getLength())
return null;
int length= 0;
while (--offset >= 0 && Character.isJavaIdentifierPart(doc.getChar(offset)))
length++;
return doc.get(offset + 1, length);
public IContextInformation[] computeContextInformation(ITextViewer viewer,
int offset) {
return NO_CONTEXTS;
public char[] getCompletionProposalAutoActivationCharacters() {
return characters;
public char[] getContextInformationAutoActivationCharacters() {
return characters;
public IContextInformationValidator getContextInformationValidator() {
return null;
public String getErrorMessage() {
return null;
| Re: IContentAssistProcessor [message #56629 is a reply to message #56601] |
Wed, 27 September 2006 16:56   |
I've gone past my initial problem. Now I get this exception:
Exception in thread "AutoAssist Delay" java.lang.NullPointerException
at org.eclipse.jface.text.contentassist.ContentAssistant$AutoAs sistListener.showAssist(ContentAssistant.java:327)
at org.eclipse.jface.text.contentassist.ContentAssistant$AutoAs sistListener.run(ContentAssistant.java:252)
at java.lang.Thread.run(Thread.java:595)
Should I give up? Does anyone have integrated a content assist processor
for a structural feature in GMF?
thanks
vlad
> Any suggestions?
> thanks in advance,
> vlad
> int i = 0;
> int offset) {
> try {
> * @param prefix
> return suggestions;
> * @param viewer
> * @param offset
> return null;
> int length= 0;
> length++;
> int offset) {
> return NO_CONTEXTS;
> return characters;
> return characters;
> return null;
> return null;
| Re: IContentAssistProcessor [message #57345 is a reply to message #56601] |
Thu, 28 September 2006 17:13  |
I've managed to get this thing to work using the field assist framework
and overriding a little bit in initCellEditor() of TextDirectEditManager.
cheers
vlad
> Any suggestions?
> thanks in advance,
> vlad
> int i = 0;
> int offset) {
> try {
> * @param prefix
> return suggestions;
> * @param viewer
> * @param offset
> return null;
> int length= 0;
> length++;
> int offset) {
> return NO_CONTEXTS;
> return characters;
> return characters;
> return null;
> return null;
Current Time: Tue Nov 18 17:17:24 EST 2025
Powered by FUDForum. Page generated in 0.09127 seconds
