Home » Eclipse Projects » Nebula » Traverse between cells using Tab key
Traverse between cells using Tab key [message #56591] Mon, 28 July 2008 04:43 Go to next message
Originally posted by: raghavdasyam.gmail.com
I am using gridviewer for Table.
I have a requirement:
On "Tab" key traverse should be happend between Cell Editors in the table.
Is the above requirement is possible? (With arrow keys traverse between
cells is already existing.)
Any reply is highly appriciated.
Advance Thanks.
Raghava
Re: Traverse between cells using Tab key [message #56700 is a reply to message #56591] Tue, 29 July 2008 04:33 Go to previous messageGo to next message
Hi Raghava,
You can extend ColumnViewerEditor class and override
processTraverseEvent method to calculate next cell and start editor in it.
Then you can set this editor to the grid viewer with
setColumnViewerEditor method.
Sergey.
Re: Traverse between cells using Tab key [message #56806 is a reply to message #56700] Fri, 01 August 2008 07:25 Go to previous messageGo to next message
Sergey Stepanenko wrote:
> Hi Raghava,
Hello Sergey,
Thanks for your reply...
I saw the code of "GridViewerEditor".Constructor is not exposed.I can't
extend GridViewerEditor.If i have to extend the ColumnViewerEditor,then i
have to implement lot of methods.Can you suggest me anything.
Raghava
Re: Traverse between cells using Tab key [message #56832 is a reply to message #56806] Fri, 01 August 2008 10:32 Go to previous messageGo to next message
>> it.
> Hello Sergey,
> i have to implement lot of methods.Can you suggest me anything.
Yes, this is a kind of trick since GridViewerEditor is not extendable -
you can extend ColumnViewerEditor and just implement three abstract
methods setEditor, setLayoutData and updateFocusCell, and you can refer
to GridViewerEditor on how to implement them.
Re: Traverse between cells using Tab key [message #56941 is a reply to message #56832] Mon, 04 August 2008 06:01 Go to previous messageGo to next message
Is the default traversing not good enough? Please see the snippets (part
of CVS) which present how to reset it. You should use the factory
methods and pass the feature constants.
Tom
>>> in it.
>> Hello Sergey,
>> can't extend GridViewerEditor.If i have to extend the
>> ColumnViewerEditor,then i have to implement lot of methods.Can you
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Traverse between cells using Tab key [message #56991 is a reply to message #56941] Mon, 04 August 2008 08:37 Go to previous messageGo to next message
For me it wasn't enough because of requirements to move between editors
in cells when user press Arrow keys (possible with Ctrl, Shift, Alt) and
PageUp/PageDown, not only Tab key.
Re: Traverse between cells using Tab key [message #57019 is a reply to message #56991] Mon, 04 August 2008 09:33 Go to previous messageGo to next message
Hm. So if a user presses and ARROW_LEFT/RIGHT in an active editor your
are jumping to the next one? The same is true for ARROW_DOWN/UP and
PAGE_DOWN/UP which e.g. people use it to select values from Combos or do
you talk about general navigation outside active
editors(Grid#setCellSelectionEnabled(true))
Tom
>> (part of CVS) which present how to reset it. You should use the
>> factory methods and pass the feature constants.
Re: Traverse between cells using Tab key [message #57072 is a reply to message #57019] Mon, 04 August 2008 10:01 Go to previous messageGo to next message
I'm talking about navigation inside editors, and yes - when user press
for example ARROW_DOWN/UP we have to move to the cell in row below/up.
Instead of Combo we use our own control (because of special
functionality), and it should be opened with Alt+ArrowDown.
Re: Traverse between cells using Tab key [message #57097 is a reply to message #57072] Mon, 04 August 2008 10:13 Go to previous messageGo to next message
Maybe we should move the code to the
ColumnViewerEditorActivationStrategy and allow users to customize it
there. Could you file a bug against Platform/UI and CC me on the bug.
Tom
>> do you talk about general navigation outside active
Re: Traverse between cells using Tab key [message #57587 is a reply to message #57097] Mon, 11 August 2008 06:14 Go to previous messageGo to next message
Hello Sergey and Tom,
I got the solution for traverse between cells using Tab key with out
extending ColumnViewerEditor with below code.
ColumnViewerEditorActivationStrategy actSupport = new
ColumnViewerEditorActivationStrategy(Viewer) {
protected boolean isEditorActivationEvent(
ColumnViewerEditorActivationEvent event) {
return event.eventType == ColumnViewerEditorActivationEvent.TRAVERSAL
|| event.eventType ==
ColumnViewerEditorActivationEvent.MOUSE_CLICK_SELECTION
|| (event.eventType == ColumnViewerEditorActivationEvent.KEY_PRESSED &&
event.keyCode == SWT.F2)|| event.eventType ==
ColumnViewerEditorActivationEvent.PROGRAMMATIC;
GridViewerEditor.create(gridViewer, actSupport,
ColumnViewerEditor.TABBING_HORIZONTAL |
ColumnViewerEditor.TABBING_MOVE_TO_ROW_NEIGHBOR
| ColumnViewerEditor.TABBING_VERTICAL |
ColumnViewerEditor.KEYBOARD_ACTIVATION );
Thanks for your support.
Regrads,
Raghava
Re: Traverse between cells using Tab key [message #59900 is a reply to message #57587] Thu, 09 October 2008 08:59 Go to previous messageGo to next message
i am able traverse between cell using tab specified code in previous
message.
I created table in one editor.
but scrollbar of the editor is not moving according to tab move.
Scrollbar is moved with arrow key navigation.
do i need to do anything explicitly.
Advance thanks for response.
Raghava
Re: Traverse between cells using Tab key [message #60033 is a reply to message #59900] Fri, 10 October 2008 06:11 Go to previous messageGo to next message
This should work, when looking at the code in header_footer branch the
code in
GridViewerEditor#updateFocusCell it looks like this:
> protected void updateFocusCell(ViewerCell focusCell, ColumnViewerEditorActivationEvent event) {
> Grid grid = ((Grid)getViewer().getControl());
> if (event.eventType == ColumnViewerEditorActivationEvent.PROGRAMMATIC
> || event.eventType == ColumnViewerEditorActivationEvent.TRAVERSAL) {
> grid.setFocusColumn(grid.getColumn(focusCell.getColumnIndex( )));
> grid.setFocusItem((GridItem) focusCell.getItem());
> grid.showColumn(grid.getColumn(focusCell.getColumnIndex()));
> grid.showItem((GridItem) focusCell.getItem());
Tom
Raghava Rao schrieb:
> Hello,
> message.
> Raghava
Re: Traverse between cells using Tab key [message #60106 is a reply to message #60033] Fri, 10 October 2008 17:37 Go to previous messageGo to next message
Hello Tom,
i tried in debug mode.it's going to updatefocuscell method.but Scrollbar
is not getting moved.
I created scrollbar on Grid.
For arrow keys scrollbar moving properly.
Advance Thanks for ur reply.
Raghava
Re: Traverse between cells using Tab key [message #60129 is a reply to message #60106] Tue, 14 October 2008 10:28 Go to previous messageGo to next message
Raghava Rao wrote:
> Hello Tom,
> Raghava
Can you sugggest me any other solution to make scrollabar update with Tab
traversing.
Advance thanks for your reply.
Raghava
Re: Traverse between cells using Tab key [message #60250 is a reply to message #60129] Wed, 22 October 2008 08:33 Go to previous message
Hello Tom,
Is this a bug?
Can u suggest any solution to make it work.
please do the needful.
Advance thanks for reply.
Raghava
Re: Traverse between cells using Tab key [message #591337 is a reply to message #56591] Tue, 29 July 2008 04:33 Go to previous message
Hi Raghava,
Sergey.
Re: Traverse between cells using Tab key [message #591374 is a reply to message #56700] Fri, 01 August 2008 07:25 Go to previous message
> Hi Raghava,
Hello Sergey,
Raghava
Re: Traverse between cells using Tab key [message #591383 is a reply to message #56806] Fri, 01 August 2008 10:32 Go to previous message
>> it.
> Hello Sergey,
Re: Traverse between cells using Tab key [message #591430 is a reply to message #56832] Mon, 04 August 2008 06:01 Go to previous message
Tom
>>> in it.
>> Hello Sergey,
Re: Traverse between cells using Tab key [message #591447 is a reply to message #56941] Mon, 04 August 2008 08:37 Go to previous message
Re: Traverse between cells using Tab key [message #591452 is a reply to message #56991] Mon, 04 August 2008 09:33 Go to previous message
Tom
Re: Traverse between cells using Tab key [message #591472 is a reply to message #57019] Mon, 04 August 2008 10:01 Go to previous message
Re: Traverse between cells using Tab key [message #591479 is a reply to message #57072] Mon, 04 August 2008 10:13 Go to previous message
Tom
Re: Traverse between cells using Tab key [message #591656 is a reply to message #57097] Mon, 11 August 2008 06:14 Go to previous message
|| event.eventType ==
Regrads,
Raghava
Re: Traverse between cells using Tab key [message #592495 is a reply to message #57587] Thu, 09 October 2008 08:59 Go to previous message
message.
Raghava
Re: Traverse between cells using Tab key [message #592533 is a reply to message #59900] Fri, 10 October 2008 06:11 Go to previous message
code in
Tom
> Hello,
> message.
> Raghava
Re: Traverse between cells using Tab key [message #592565 is a reply to message #60033] Fri, 10 October 2008 17:37 Go to previous message
Hello Tom,
Raghava
Re: Traverse between cells using Tab key [message #592574 is a reply to message #60106] Tue, 14 October 2008 10:28 Go to previous message
Raghava Rao wrote:
> Hello Tom,
> Raghava
traversing.
Raghava
Re: Traverse between cells using Tab key [message #592627 is a reply to message #60129] Wed, 22 October 2008 08:33 Go to previous message
Hello Tom,
Is this a bug?
Raghava
Previous Topic:CompositeTable selection question
Next Topic:Grid - data into Excel
Current Time: Fri Nov 28 03:05:13 EST 2025
Powered by FUDForum. Page generated in 0.13013 seconds
