Home » Eclipse Projects » DTP » db4o database in the Data Tools Platfom
db4o database in the Data Tools Platfom [message #56586] Fri, 22 May 2009 12:20 Go to next message
Hi.
I'm curious whether an object database like db4o
(http://developer.db4o.com) could be integrated in the Data Tools
Platform. They are already supporting Eclipse with:
a) an Eclipse plugin to browse stored objects (you can check it out in the
Java/Eclipse getting started video ->
http://developer.db4o.com/blogs/community/archive/2009/05/21 /second-getting-started-with-db4o-video-java.aspx)
b) a second Eclipse plugin to instrument objects to work with db4o
transparently
( http://developer.db4o.com/blogs/product_news/archive/2009/05 /18/automagically-enable-db4o-transparent-persistence-for-ja va-via-eclipse.aspx)
Could this be a start to integrate db4o into DTP or DTP is only targeted
at relational datastores? How about db4o as part of EclipseLink?
Best (thx)
Re: db4o database in the Data Tools Platfom [message #56667 is a reply to message #56586] Tue, 26 May 2009 17:58 Go to previous message
Originally posted by: brianf.sybase.com
Hi there...
Well, we're always looking for more databases to integrate with. Can't say I
know anything about db4o, but if it has a JDBC driver, we can most likely
connect to it or DTP can be adapted to work with it.
If you want to see a series of articles on integrating a different database
(SQLite) with DTP, you can check out these articles on my blog...
http://fitzdtp.blogspot.com/2008/06/how-do-you-add-your-own- custom-driver.html
http://fitzdtp.blogspot.com/2008/08/dtp-sqlite-support-conti nued-on-to.html
http://fitzdtp.blogspot.com/2008/08/creating-sqlite-connecti on-profile-ui.html
Hope that helps! We're always looking for community support for new
databases, so if you get something working and want to contribute it back,
we'd love to have it. Also, feel free to put up any questions you may have
and we'll do our best to answer them!
Thanks!
--Fitz
"gerpx " <german@rebels.com> wrote in message
news:06a0ed57f8c9fba513a20156a092be92$1@www.eclipse.org...
> Hi.
> transparently
> Best (thx)
Re: db4o database in the Data Tools Platfom [message #595853 is a reply to message #56586] Tue, 26 May 2009 17:58 Go to previous message
Hi there...
Thanks!
--Fitz
> Hi.
> transparently
> Best (thx)
Previous Topic:Informix - error "Method can be called only once."
Next Topic:Installation blocked by DTP
Current Time: Thu Nov 20 00:45:42 EST 2025
Powered by FUDForum. Page generated in 0.03853 seconds
