Home » Archived » EPF » Supporting material appears twice in EPF
Supporting material appears twice in EPF [message #56557] Fri, 03 April 2009 06:01 Go to next message
I posted this question yesterday, but probably in a wrong newgroup
(newcomers). So I post it again here :
I have a problem with guidances which appears twice in a task. I’m using
the EPF version 1.5.0.1
I've a sample test library which contains one plug-in with :
- one task, with one Work product, one Role, and one Guidance (Supporting
material type)
- one process, as Capability pattern, containing the task - one discipline
(standard category), containing the task
- one custom category, containing the Supporting material
- one custom category, containing the process
- one configuration associated to the process
When I publish the configuration with 3 views (one for each category), I
have the following problems :
- the supporting material appears twice in the task included into the
process
- the task appears twice in the supporting material view
But in the Discline view, the task content is OK, with one occurrence of
Before publishing, I’ve synchronised the process. Publishing options
(layout)are all activated
If I desactivate the last option “Include method content in page
descriptor”, the supporting material doesn’t appears twice. But if this
option is disactivated, the content of the task appears on a linked page
(task based on Method Task…) and I wouldn’t like this.
I can send a zip of this library and/or screens hardcopy if necessary.
Thank you for your time and help
Yves.
Re: Supporting material appears twice in EPF [message #56584 is a reply to message #56557] Fri, 03 April 2009 07:07 Go to previous message
I find that this problem is fixed in 1.5.02 release. It works fine now.
Yves.
Re: Supporting material appears twice in EPF [message #598616 is a reply to message #56557] Fri, 03 April 2009 07:07 Go to previous message
Yves.
Previous Topic:Supporting material appears twice in EPF
Next Topic:Problem to update Wiki
Current Time: Mon Nov 03 20:36:58 EST 2025
Powered by FUDForum. Page generated in 0.06030 seconds
