Identical files when debugging with xdebug in PDT 1.0 [message #56532] |
Wed, 03 October 2007 09:37  |
Originally posted by: newsgroup.bobsworld.be
Hello all
I think this was a bug I had in one of the previous releases. When I
have these files in my project:
modules/admin/text.php
modules/user/text.php
And I try to debug modules/user/text.php and set a breakpoint, PDT stops
at the breakpoint (correct line number) but PDT opens the wrong file (in
this case modules/admin/text.php).
Is this a known bug or is something wrong with my configuration? Has any
body any suggestions or workarounds?
Server (debian)
Apache/2.2.4 (Debian)
PHP Version 5.2.3
Xdebug v2.0.0RC3
Workstation (winxp)
pdt-all-in-one-1.0-R20070917-win32
Greets
Johan Vandeweerd
Re: Identical files when debugging with xdebug in PDT 1.0 [message #56608 is a reply to message #56585] |
Wed, 03 October 2007 14:11   |
Originally posted by: news.kasimir-k.fi
I experience the same behavior. My setup is very similar, except my
server is on the same WinXP (Apache 2.2.4, PHP 5.2.2, Xdebug 2.0.0 (was
rc4, no difference)).
..k
Johan Vandeweerd scribeva in 03/10/2007 16:21:
> Hello
> Apache (debian) has it's document root under "/var/www". I have multiple
> subdomains and each subdomain has it's own directory in "/var/www"
> reflecting it's domainname (virtual hosts).
> The "/var/www" directory is shared with samba for my windows pc.
> On my windows pc i use PDT 1.0 and I created a new project in
> "/var/www/www.example.com". I use a front controller that parses the uri
> and looks for the correct module and includes that module.
> For example if I go to "www.example.com/admin/text", it will include the
> module "modules/admin/text.php" and if you go to "www.example.com/text"
> it wil include "modules/default/text.php".
> When placing the breakpoint in "modules/default/text.php", it stops at
> the breakpoint (correct line number), it shows all the variables of the
> correct script ("modules/default/text.php") in the variables window, it
> shows the correct path in the debug screen (stacktrace) eg
> "/var/www/www.example.com/modules/default/text.php" but the content of
> the editor is the content of "modules/admin/text.php" file (the one he
> encounters first I guess).
> In the debug launch setup, I have the following for tab Server:
> Server Debugger: XDebug
> PHP Server: the name of my local debian server (configured and changed
> the name)
> File / Project: /projectname/
> Publish to server: disabled
> Break at first line: unchecked
> Auto generate url: manually adjusted to reflect my setup
> tab Advanced:
> Open in browser: checked
> Debug all pages selected
> tab Common: unchanged
> Also upgraded to xdebug 2.0 btw.
> Any idea's?
> Thanks in advance
> Johan Vandeweerd
> Dave Kelsey wrote:
>> Hi Johan,
>> A simple test with 2 files of the same name worked fine for me so I think
>> you need to describe your document root setup, workspace setup and the
>> debug
>> launch setup.
>> I would also suggest moving to the official 2.0 release of XDebug as I
>> don't
>> know if PDT will work properly with RC3 anymore.
>> Dave Kelsey
>> Johan Vandeweerd wrote:
>>> Hello all
>>> stops at the breakpoint (correct line number) but PDT opens the wrong
>>> file (in this case modules/admin/text.php).
>>> any body any suggestions or workarounds?
>>> Server (debian)
>>> PHP Version 5.2.3
>>> Xdebug v2.0.0RC3
>>> Workstation (winxp)
>>> Greets
>>> Johan Vandeweerd
Re: Identical files when debugging with xdebug in PDT 1.0 [message #56662 is a reply to message #56585] |
Wed, 03 October 2007 16:11   |
Originally posted by: dkel50.hotnospmail.com
Johan, in the launch configuration you need to specify the name of the
file that gets launched when the particular URL is specified. This is
how the auto pathmapper determines the path difference between the files
in your project and the files on the web server. Specifying a project
only means that path mapping won't work.
Try changing the launch and see if it helps.
Dave Kelsey
> Hello
> the name)
> tab Advanced:
> Any idea's?
> Thanks in advance
> Johan Vandeweerd
> Dave Kelsey wrote:
>> Hi Johan,
>> debug
>> launch setup.
>> don't
>> Dave Kelsey
>>> Hello all
>>> Server (debian)
>>> PHP Version 5.2.3
>>> Xdebug v2.0.0RC3
>>> Workstation (winxp)
>>> Greets
>>> Johan Vandeweerd
Re: Identical files when debugging with xdebug in PDT 1.0 [message #56770 is a reply to message #56662] |
Thu, 04 October 2007 01:51  |
Hello Dave
In my launch configuration I selected the index.php in the root of my
project and now it works. Thanks again.
Johan Vandeweerd
> Dave Kelsey
>> Hello
>> multiple subdomains and each subdomain has it's own directory in
>> "/var/www" reflecting it's domainname (virtual hosts).
>> uri and looks for the correct module and includes that module.
>> the module "modules/admin/text.php" and if you go to
>> "www.example.com/text" it wil include "modules/default/text.php".
>> the correct script ("modules/default/text.php") in the variables
>> window, it shows the correct path in the debug screen (stacktrace) eg
>> the name)
>> tab Advanced:
>> Any idea's?
>> Thanks in advance
>> Johan Vandeweerd
>> Dave Kelsey wrote:
>>> Hi Johan,
>>> think
>>> the debug
>>> launch setup.
>>> I don't
>>> Dave Kelsey
>>>> Hello all
>>>> wrong file (in this case modules/admin/text.php).
>>>> Server (debian)
>>>> PHP Version 5.2.3
>>>> Xdebug v2.0.0RC3
>>>> Workstation (winxp)
>>>> Greets
>>>> Johan Vandeweerd
FUDForum. Page generated in 0.03642 seconds
