Home » Archived » Test and Performance Tools Platform (TPTP) » Problems installing and using TPTP Automated GUI Recorder
Problems installing and using TPTP Automated GUI Recorder [message #56514] Tue, 07 March 2006 10:24 Go to next message
Originally posted by: ffejbrown.yahoo.com
I am trying to follow the TPTP Tutorial "An Introduction to Using TPTP's
Automated GUI Recorder" and I am having problems with it. It seems when I
am following this guide, I do not get the same results as the
demonstration. Specifically, the Examine Macro tab is not present after
I've recorded the steps in the tutorial. In fact, it is never displayed.
I have followed the setup guide at
http://www.eclipse.org/tptp/home/downloads/installguide/Inst allGuide41.html
and have followed the tutorial step by step
( http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI.html#1.1)
Has anyone else had a problem with the Examine Macro tab not appearing in
the workspace?
Any help would be appreciated.
Jeff
Re: Problems installing and using TPTP Automated GUI Recorder [message #56545 is a reply to message #56514] Tue, 07 March 2006 14:02 Go to previous messageGo to next message
I did the tutorial using TPTP version 4.1 and the examine macro tab was not
there as well. But in version 4.2 it is. I think it is a feature that was
introduced in 4.2.
Heidi
"Jeff Brown" <ffejbrown@yahoo.com> wrote in message
news:86dadfc55ad950afc762c699cc60975f$1@www.eclipse.org...
> the workspace?
> Jeff
Re: Problems installing and using TPTP Automated GUI Recorder [message #56569 is a reply to message #56514] Tue, 07 March 2006 16:35 Go to previous messageGo to next message
Yep, it was a feature added in 4.2.
I will create different versions of the user guide for each release.
I've created https://bugs.eclipse.org/bugs/show_bug.cgi?id=130817 to follow
upon this.
..1)
> the workspace?
> Jeff
Re: Problems installing and using TPTP Automated GUI Recorder [message #57435 is a reply to message #56569] Fri, 10 March 2006 14:20 Go to previous messageGo to next message
Thanks for the feedback. I'm still having issues getting the Examine
Macro tab to appear. I tried adding TPTP 4.2 with the 3.1.2 SDK but the
testing options for File>New>Other... was not event available. I then
deleted my workbench and reinstalled the following:
eclipse-SDK-3.2M5a-win32
emf-sdo-SDK-2.1.2
xsd-SDK-2.1.2
tptp.sdk-TPTP-4.2.0-200602281515
org.eclipse.tptp.test.auto-TPTP-4.1.0.1
With this setup, I'm still not seeing the Examine Macro tab. Am I missing
anything? Is there a 4.2 version of the Automated Gui Tester that I can't
find? Any help would be appreciated.
Jeff
Re: Problems installing and using TPTP Automated GUI Recorder [message #57668 is a reply to message #57435] Sun, 12 March 2006 18:54 Go to previous messageGo to next message
# Java runtime (JRE) or Java development kit (JDK) 1.4
# Eclipse SDK 3.2.0 M5a
# Eclipse Modeling Framework (EMF and XSD) SDK 2.2.0 M5
These are the first three items from the Requirements listing on that
download page (TPTP 200602281515). Note the 2.2.0M5 requirement for
EMF/XSD/SDO.
RDS
> emf-sdo-SDK-2.1.2
> xsd-SDK-2.1.2
> missing anything? Is there a 4.2 version of the Automated Gui Tester
> that I can't find? Any help would be appreciated.
> Jeff
Re: Problems installing and using TPTP Automated GUI Recorder [message #57836 is a reply to message #57668] Mon, 13 March 2006 10:17 Go to previous messageGo to next message
Thanks Randy!
I upgrade the EMF/SDO/XSD to emf-sdo-xsd-SDK-2.2.0M5.zip and I found
org.eclipse.tptp.test.auto-TPTP-4.2.0-200512011334 and installed that too.
I still do not get 'Examine Macro Tab' after recording an Automated Test.
I have to be missing something big.
-Jeff
Re: Problems installing and using TPTP Automated GUI Recorder [message #58149 is a reply to message #57836] Tue, 14 March 2006 15:11 Go to previous messageGo to next message
The auto gui plugin driver should match the same driver as tptp. When you
select a TPTP driver to downlad, use the auto gui plugin that is present on
the *same* download page under the technology preview heading.
news:53e24410e83e65ff290dd8cff8918e9f$1@www.eclipse.org...
> Thanks Randy!
> -Jeff
Re: Problems installing and using TPTP Automated GUI Recorder [message #59065 is a reply to message #58149] Fri, 17 March 2006 16:11 Go to previous message
Thanks for the help!
I installed the following and everything worked fine:
1. eclipse-SDK-3.2M5a-win32
2. emf-sdo-xsd-SDK-2.2.0M5
3. tptp.sdk-TPTP-4.2.0-200602281515
4. org.eclipse.tptp.test.auto-TPTP-4.2.0-200602281515
Previous Topic:TPTP on Eclipse 3.2M5a
Next Topic:Finding all objects that were created
Current Time: Wed Jul 30 18:13:50 EDT 2025
Powered by FUDForum. Page generated in 0.03860 seconds
