Home » Eclipse Projects » Nebula » DateChooserComboObservableValue & databinding
DateChooserComboObservableValue & databinding [message #56508] Mon, 21 July 2008 16:59 Go to next message
--------------070800050507070305050303
for my needs I wrote the "IObservableValue" for the DateChooserCombo widget.
It seems to work and I want to share it with the community.
Please send me your feedbacks
name="DateChooserComboObservableValue.java"
Content-Disposition: inline;
filename="DateChooserComboObservableValue.java"
package com.adeo.rcp.technique.observables;
import java.util.Date;
import org.eclipse.core.databinding.observable.Diffs;
import org.eclipse.core.databinding.observable.value.AbstractObserv ableValue;
import org.eclipse.core.databinding.observable.value.IObservableVal ue;
import org.eclipse.jface.databinding.swt.SWTObservables;
import org.eclipse.nebula.widgets.datechooser.DateChooserCombo;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.DisposeEvent;
import org.eclipse.swt.events.DisposeListener;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
* @author Pascal Leclercq
public class DateChooserComboObservableValue extends AbstractObservableValue implements IObservableValue {
* The Control being observed here.
protected final DateChooserCombo dateChooserCombo;
* Flag to prevent infinite recursion in {@link #doSetValue(Object)}.
protected boolean updating = false;
* The "old" value before a selection event is fired.
protected Date oldValue;
* SWT event that on firing this observable will fire change events to its
* listeners.
private final int updateEventType;
* Valid types for the {@link #updateEventType}.
private static final int[] validUpdateEventTypes = new int[] { SWT.Modify, SWT.FocusOut, SWT.None };
* Observe the selection property of the provided DateChooserCombo control.
* @param dateChooserCombo
* the control to observe
public DateChooserComboObservableValue(DateChooserCombo dateChooserCombo, int updateEventType) {
super(SWTObservables.getRealm(dateChooserCombo.getDisplay()) );
boolean eventValid = false;
for (int i = 0; !eventValid && i < validUpdateEventTypes.length; i++) {
eventValid = (updateEventType == validUpdateEventTypes[i]);
if (!eventValid) {
throw new IllegalArgumentException("UpdateEventType [" + updateEventType + "] is not supported."); //$NON-NLS-1$//$NON-NLS-2$
this.dateChooserCombo = dateChooserCombo;
oldValue = dateChooserCombo.getValue();
this.updateEventType = updateEventType;
if (updateEventType != SWT.None) {
dateChooserCombo.addListener(updateEventType, updateListener);
dateChooserCombo.addDisposeListener(disposeListener);
private DisposeListener disposeListener = new DisposeListener() {
public void widgetDisposed(DisposeEvent e) {
DateChooserComboObservableValue.this.dispose();
public void dispose() {
if (!dateChooserCombo.isDisposed()) {
dateChooserCombo.removeListener(updateEventType, updateListener);
super.dispose();
public Object getValueType() {
return Date.class;
protected Object doGetValue() {
return dateChooserCombo.getValue();
private Listener updateListener = new Listener() {
public void handleEvent(Event event) {
if (!updating) {
Date newValue = dateChooserCombo.getValue();
if (!newValue.equals(oldValue)) {
fireValueChange(Diffs.createValueDiff(oldValue, newValue));
oldValue = newValue;
protected void doSetValue(Object value) {
Date newValue;
try {
updating = true;
newValue = (Date) value;
dateChooserCombo.setValue(newValue);
} finally {
updating = false;
--------------070800050507070305050303--
Re: DateChooserComboObservableValue & databinding [message #56916 is a reply to message #56508] Mon, 04 August 2008 05:58 Go to previous messageGo to next message
Please file a bug and attach the sources.
Tom
Pascal Leclercq schrieb:
> widget.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: DateChooserComboObservableValue & databinding [message #58751 is a reply to message #56916] Tue, 02 September 2008 17:23 Go to previous messageGo to next message
Hi Tom,
it's done here :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=246014.
Thanks for your great work !
> Tom
>> widget.
Re: DateChooserComboObservableValue & databinding [message #58776 is a reply to message #56916] Tue, 02 September 2008 17:30 Go to previous messageGo to next message
Hi Tom,
it's done here :
> Tom
>> widget.
Re: DateChooserComboObservableValue & databinding [message #63030 is a reply to message #58776] Tue, 21 April 2009 05:02 Go to previous messageGo to next message
--------------060800090405050006040803
Pascal, thanks for your IObservableValue implementation.
IMO, the implementation does not recognize incomplete values in the
text-field.
If the user only inputs the "date" '11.11.' without a year, the
databinding will not become "active" (because the combo delivers a null
date) and we cannot validate the user input correctly.
My idea is that the implementation should return a string which can be
validated and converters will convert the string into a date and vice versa.
Is there any other solution?
Do you see any problems with that approach?
Jens
Am 02.09.2008 23:30, schrieb Pascal Leclercq:
> Hi Tom,
> it's done here :
> Tom Schindl a
Re: DateChooserComboObservableValue & databinding [message #528071 is a reply to message #63030] Mon, 19 April 2010 04:25 Go to previous messageGo to next message
I tried to implement the .getText() solution for validation. But the problem ist, the validate method is only called in after at least one digit for each field (day, month, year) is set. The nebula DateChooserCombo only allows to enter valid digits in the single fields. So the only sense would be the menitoned case, of half entered dates (e.g. '11.1.').
But as the validate method is not called in this case, there is nothing one can do about it.
Or do I miss something?
best regards,
Andreas
Re: DateChooserComboObservableValue & databinding [message #591424 is a reply to message #56508] Mon, 04 August 2008 05:58 Go to previous messageGo to next message
Tom
> widget.
Re: DateChooserComboObservableValue & databinding [message #592093 is a reply to message #56916] Tue, 02 September 2008 17:23 Go to previous messageGo to next message
Hi Tom,
it's done here :
> Tom
>> widget.
Re: DateChooserComboObservableValue & databinding [message #592099 is a reply to message #56916] Tue, 02 September 2008 17:30 Go to previous messageGo to next message
Hi Tom,
it's done here :
> Tom
>> widget.
Re: DateChooserComboObservableValue & databinding [message #594500 is a reply to message #58776] Tue, 21 April 2009 05:02 Go to previous messageGo to next message
text-field.
Jens
> Hi Tom,
> it's done here :
> Tom Schindl a
Re: DateChooserComboObservableValue & databinding [message #599495 is a reply to message #63030] Mon, 19 April 2010 04:25 Go to previous message
best regards,
Andreas
Previous Topic:About Nebula XViewer
Next Topic:[CDateTime] DoubleClick to select day
Current Time: Sat Nov 22 04:19:54 EST 2025
Powered by FUDForum. Page generated in 0.18548 seconds
