| Theme problem [message #56499] |
Tue, 30 October 2007 16:00  |
i've set in my theme properties file the field
shell.title.background = #000000
in order to change the background in the shell title; anyway nothing
happens and the color remains the default one (blue). changing another
prop in the file, it works fine.
I've put also in the code the following sys.out
System.out.println(PlatformUI.getWorkbench().getDisplay().ge tSystemColor(SWT.COLOR_TITLE_BACKGROUND));
and it prints
Color {0, 0, 0}
So the color black is set but the shell title background is not refreshed.
Any suggestion?
Christian
| Re: Theme problem [message #56661 is a reply to message #56606] |
Wed, 31 October 2007 12:08  |
Originally posted by: rsternberg.innoopract.com
Hi Christian,
A background image covers the widget background and thus hides the
background color. Setting the background image to "none" should work.
Background gradients are not yet supported. The only effect of setting
the bg gradient color is that the corresponding SWT System Color changes.
Best Regards,
Ralf
Christian schrieb:
> the bg gradient doesn't work. Any suggestions?
> Christian
> Benedikt Arnold ha scritto:
>> Hi!
>> Here is my complete Theme file. Try to set the background gradient too.
>> # Background color for the title bar of active Shells
>> # default: #0080c0
>> shell.title.background: #678187
>> # Second background color for the title bar of active Shells (used for
>> gradient)
>> # default: #0080c0
>> shell.title.background.gradient: #678187
>> # Background image for title bar of active Shells
>> # default:
>> shell.title.active.bgimage: none
>> # Border for shells without BORDER and TITLE style
>> # default: 1px solid black
>> shell.border: 1px solid #678187
>> # Border for shells with BORDER or TITLE style
>> # default: 2px outset
>> shell.BORDER.border: 2px outset #678187
>> list.selection.background: #a0bf7d
>> "Christian" <zerostress@libero.it> schrieb im Newsbeitrag
>> news:fg9fnr$fk7$1@build.eclipse.org...
>>> Hi Ben,
>>> with the bgimage=none it doesn't work...but if i use an image, the bg
>>> color is set.
>>> Thanks a lot
>>> Christian
>>>> Hi!
>>>> I got the same problem some days ago. Try to unset the title background
>>>> image like this
>>>> and then set the title background color.
>>>> Greetings,
>>>> Ben
>>>> news:fg82h6$4a3$1@build.eclipse.org...
>>>>> Hi,
>>>>> and it prints
>>>>> Color {0, 0, 0}
>>>>> refreshed.
>>>>> Any suggestion?
>>>>> Thanks
>>>>> Christian
FUDForum. Page generated in 0.05598 seconds
