Home » Modeling » M2T (model-to-text transformation) » JET2 merging of model data with existing Java code
JET2 merging of model data with existing Java code [message #56454] Mon, 26 January 2009 10:26 Go to next message
In
http://www-128.ibm.com/developerworks/java/library/os-ecl-je t/index.html?ca=drs
the authors mention tag libraries that appear to load java code as input
models (
http://wiki.eclipse.org/JET_FAQ_What_kind_of_input_model_can _JET_handle%3F);
"org.eclipse.jet.modelInspectors
This allows you to define inspectors that enable the JET XPath engine to
interpret loaded Java objects as XPath nodes. An inspector is an object
that adapts objects to the XPath information model. As an example, JET
uses a model to navigate the Eclipse workspace. Note that this is a
provisional API, and that it is likely to evolve over time."
... or if not strictly input models then allowing me process a JDT tree
and XML model at the same time?
Has this been ambandoned in favour of using JMerge?
Thanks...
Re: JET2 merging of model data with existing Java code [message #56512 is a reply to message #56454] Tue, 27 January 2009 11:10 Go to previous messageGo to next message
JF:
No, the modelInspectors approach has not been abandoned. JET2 already has
the following inspectors:
* XML DOM Node objects
* EMF EObject object (which covers any EMF-based model in existance)
* Eclipse workspaces IResource objects
I will be adding to this list in the Galileo release:
* JDT trees
I hope also, to add the ability to navigate (but no promises)
* java.util.Properties
* Manifest files
But, that doesn't mean you should leave JMerge behind.
Paul
Re: JET2 merging of model data with existing Java code [message #56534 is a reply to message #56512] Tue, 27 January 2009 17:51 Go to previous messageGo to next message
Originally posted by: tmothymarc.freenet.de
Hi Paul,
just a simple question. With JDT tree, you mean the AST created by the
JDT or what else?
Thx
Timothy
Paul Elder schrieb:
> JF:
> * JDT trees
> * Manifest files
> Paul
Re: JET2 merging of model data with existing Java code [message #56642 is a reply to message #56534] Thu, 29 January 2009 09:44 Go to previous messageGo to next message
Timothy:
I mean the all the descendents of ASTNode:
http://help.eclipse.org/ganymede/topic/org.eclipse.jdt.doc.i sv/reference/api/org/eclipse/jdt/core/dom/ASTNode.html
Paul
"Timothy Marc" <tmothymarc@freenet.de> wrote in message
news:glo34r$hfi$1@build.eclipse.org...
> Hi Paul,
> just a simple question. With JDT tree, you mean the AST created by the JDT
> or what else?
> Thx
> Timothy
> Paul Elder schrieb:
>> JF:
>> * JDT trees
>> * Manifest files
>> Paul
Re: JET2 merging of model data with existing Java code [message #56749 is a reply to message #56642] Sun, 01 February 2009 09:53 Go to previous message
Okay, thanks Paul.
i think this enhancement would be quite fantastic.
Paul Elder schrieb:
> Timothy:
> Paul
>> Hi Paul,
>> or what else?
>> Thx
>> Timothy
>> Paul Elder schrieb:
>>> JF:
>>> * JDT trees
>>> * Manifest files
>>> Paul
Previous Topic:[JET2] Iterating through the elements of an EList in an EMF model
Next Topic:[Announce] M2T XPAND 0.7.0 M200902040403 is available
Current Time: Mon Jul 14 19:56:21 EDT 2025
Powered by FUDForum. Page generated in 0.05137 seconds
