Home » Archived » Visual Editor (VE) » internal error
internal error [message #56421] Fri, 20 August 2004 10:16 Go to next message
Originally posted by: nospam.cucu.org
Hi to all,
I've installed VE 1.0.0 (and GEF, EMF) on Eclipse 3.0 final.
When I try to create a Java Visual Class I have some problem...
The first window (the one which asks me the class name) opens normally,
but when I hit Finish I see the Visual Editor empty (with a strange
%Palette.Label on the beans palette) and a window that says to me:
Errors Running Operations
Setup Java Visual Editor (Error: An internal error occurred during:
"Setup Java Visual Editor".)
If I click on the string above I see the following message:
An internal error occurred during: "Setup Java Visual Editor".
java.lang.StackOverflowError
Eclipse worked fine before the VE installation so what have I missed?
Roberto Gianassi
Re: internal error [message #56448 is a reply to message #56421] Fri, 20 August 2004 11:54 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Please list the drivers of GEF and EMF you are using. Also, what
operating system.
Thanks, Rich Kulp
Re: internal error [message #56475 is a reply to message #56421] Fri, 20 August 2004 12:25 Go to previous messageGo to next message
Originally posted by: sttn.sttn.de
I get the same error. Reason: emf-sdo-xsd-SDK-M200408190924.zip
I use a older version (emf-sdo-xsd-SDK-M200408040957.zip) an now it
works fine
Roberto Gianassi wrote:
> Hi to all,
> Roberto Gianassi
Re: internal error [message #56502 is a reply to message #56475] Fri, 20 August 2004 13:10 Go to previous messageGo to next message
> works fine
>> Hi to all,
<snip />
I set up the old version M200408040957. I run Eclipse with the -clean
option and the label is OK, but when I create a dialog I don't see
anything in the editor window.
If I launch Eclipse without the -clean option the palette title becomes
again %Palette.Label.
An other VERY VERY VERY curious thing: if I remove/add the Javadoc
comment to the initialize method from the source view and then I switch
back to the editor I SEE the dialog (this is true independently of the
clean option and I'm wondering why, however)!
I'm using (now) GEF SDK 3.0.0, EMF SDK 2.0.1.M200408040957 on WinXP HOME.
Ah, I'm using VE SDK 1.0.0.
Re: internal error [message #56527 is a reply to message #56502] Fri, 20 August 2004 13:48 Go to previous messageGo to next message
At the moment please step back to EMF 2.0.0. At this time we don't work
with some of the EMF 2.0.1 drivers. They put out a breaking change last
week and that change is being fixed so it is not breaking.
Thanks, Rich Kulp
Re: internal error [message #56552 is a reply to message #56527] Fri, 20 August 2004 14:26 Go to previous messageGo to next message
Ok, done and it seems to work.
I deinstalled the EMF examples, too (with those installed VE doesn't start).
How I know an update is available?
Thanks, again.
Re: internal error [message #56578 is a reply to message #56552] Fri, 20 August 2004 15:42 Go to previous message
When we have the official final release, the update manager will find
it. Until then you go the download site and check. For major drivers,
which are called milestone drivers, the announcement is made in this
newsgroup. Until then we have approx. one integration driver a week.
Thanks, Rich Kulp
Re: internal error [message #597442 is a reply to message #56421] Fri, 20 August 2004 11:54 Go to previous message
operating system.
Thanks, Rich Kulp
Re: internal error [message #597447 is a reply to message #56421] Fri, 20 August 2004 12:25 Go to previous message
works fine
> Hi to all,
> Roberto Gianassi
Re: internal error [message #597454 is a reply to message #56475] Fri, 20 August 2004 13:10 Go to previous message
> works fine
>> Hi to all,
<snip />
Re: internal error [message #597459 is a reply to message #56502] Fri, 20 August 2004 13:48 Go to previous message
Thanks, Rich Kulp
Re: internal error [message #597465 is a reply to message #56527] Fri, 20 August 2004 14:26 Go to previous message
Thanks, again.
Re: internal error [message #597472 is a reply to message #56552] Fri, 20 August 2004 15:42 Go to previous message
Thanks, Rich Kulp
Previous Topic:internal error
Next Topic:VE will not start properly with N20040819 and 1.0M2
Current Time: Fri Nov 14 14:47:16 EST 2025
Powered by FUDForum. Page generated in 0.07310 seconds
