Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo HibernateResource
Teneo HibernateResource [message #56398] Wed, 04 October 2006 04:56 Go to next message
Originally posted by: hodi_.gmx.at
I'm using EMF with a database and also with XMLs being stored on clients.
What I want to do is receive XMLResources from a client and store them to
the database using a HibernateResource. Tried to do this by using the
method Resource.load(InputStream arg0, Map arg1) for building the resource
from a XML-String, anyway, I saw that HibernateResource doesn't implement
this method.
Is there a way to fill a HibernateResource with a xml string?
I'm new to EMF and teneo so I'm even not sure if this would be the best
way to store XMLResources into the database. So any tips would be
helpful...thanks!
- Dietmar -
Re: Teneo HibernateResource [message #56429 is a reply to message #56398] Wed, 04 October 2006 05:15 Go to previous messageGo to next message
Hi Dietmar,
You can also use the hbDataStore.importDataStore method. The second format parameter of this method
determines if a xml or xmi import should be done (you can use the constants
HbConstants.EXCHANGE_FORMAT_XML or HbConstants.EXCHANGE_FORMAT_XMI for this).
If you want more control you can also write the import yourselve on the basis of the code in this
method (see cvs), it is only a few lines of code.
The hbDataStore also offers an export method to export the content of a database to xml or xmi.
gr. Martin
Dietmar Holzer wrote:
> clients. What I want to do is receive XMLResources from a client and
> store them to the database using a HibernateResource. Tried to do this
> by using the method Resource.load(InputStream arg0, Map arg1) for
> building the resource from a XML-String, anyway, I saw that
> HibernateResource doesn't implement this method.
> helpful...thanks!
> Cheers,
> - Dietmar -
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo HibernateResource [message #56754 is a reply to message #56429] Thu, 05 October 2006 06:34 Go to previous message
Hi Martin,
thanks a lot, seems to be exactly that what I was looking for...
- Dietmar -
Re: Teneo HibernateResource [message #593570 is a reply to message #56398] Wed, 04 October 2006 05:15 Go to previous message
Hi Dietmar,
gr. Martin
> helpful...thanks!
> Cheers,
> - Dietmar -
The Netherlands
Re: Teneo HibernateResource [message #593759 is a reply to message #56429] Thu, 05 October 2006 06:34 Go to previous message
Hi Martin,
- Dietmar -
Previous Topic:Teneo: HibernateException when trying to save HibernateResource
Next Topic:JET templates for interfaces missing with EMF 2.2.1
Current Time: Wed Nov 19 18:22:23 EST 2025
Powered by FUDForum. Page generated in 0.04037 seconds
