Home » Eclipse Projects » Mylyn » JIRA filter not showing full results as a Mylyn query
JIRA filter not showing full results as a Mylyn query [message #56371] Thu, 21 August 2008 12:07 Go to next message
Eclipse 3.4
Mylyn 3.0.1
JIRA Connector 3.0.1
JIRA Enterprise Edition, Version: 3.12-#298
I have one particular Filter defined our JIRA repository that does not
render correct results when I create a Mylyn Query from it. In the JIRA
web UI, it shows over 100 results but the Query in the Task List only
shows a handful. I've tried synchronizing and even deleting/recreating
the Query, but it always only shows a few of the expected issues in the
Task List.
When I synch or create the Query, the progress dialog looks like it is
retrieving a lot of issues/tasks, many more than what eventually show up
in the Task List.
Is there any more hints to try or information to be gathered before I
enter a bug about it?
Eric
Re: JIRA filter not showing full results as a Mylyn query [message #56395 is a reply to message #56371] Thu, 21 August 2008 16:06 Go to previous messageGo to next message
> Eclipse 3.4
> Mylyn 3.0.1
> Task List.
I am not aware of another bug that describes a similar problem. Please go
ahead and file a new bug and include any details that could help to
reproduce this.
> in the Task List.
I assume that you have have checked the error log already and there is no
indication of an error in the task list (i.e. no warning icon on the
query).
You can also check the setting for "Max number of search results" in the
repository properties under "Additional Settings", it should be set to a
higher value than the number of search results expected.
Steffen
Re: JIRA filter not showing full results as a Mylyn query [message #56420 is a reply to message #56371] Fri, 22 August 2008 08:56 Go to previous message
While poking around in the Task List view menu, I noticed an option,
"Filter Completed Tasks" that was enabled. Turning that off revealed the
tasks (this particular query is for "All issues fixed in release x" so
most of them were being filtered.
Is that a new option in Mylyn 3? Is there any existing bug report to
have that turned off as the default?
Eric
Eric Rizzo wrote:
> Eclipse 3.4
> Mylyn 3.0.1
> Task List.
> in the Task List.
> Eric
Re: JIRA filter not showing full results as a Mylyn query [message #592657 is a reply to message #56371] Thu, 21 August 2008 16:06 Go to previous message
> Eclipse 3.4
> Mylyn 3.0.1
> Task List.
reproduce this.
> in the Task List.
query).
Steffen
Re: JIRA filter not showing full results as a Mylyn query [message #592670 is a reply to message #56371] Fri, 22 August 2008 08:56 Go to previous message
Eric
Eric Rizzo wrote:
> Eclipse 3.4
> Mylyn 3.0.1
> Task List.
> in the Task List.
> Eric
Previous Topic:Using weekly updates with Eclipse 3.3.2
Next Topic:Generic Connector Login URL problems
Current Time: Tue Oct 21 14:42:53 EDT 2025
Powered by FUDForum. Page generated in 0.09835 seconds
