make a figure not selectable/movable/resizable [message #56357] |
Sun, 19 January 2003 17:09  |
Originally posted by: radienssmgs2.hotmail.com
I try to make a figure not selectable/movable/resizable but creating a
NullEditPolicy which is a subclass of GraphicalEditPolicy.
This seems to work, since I can no longer click on it and select it. But I
can still select by using the Marquee. How can I REMOVE that functionality?
in other word, user can not select this figure using marquee (but it can
still use to select other figure)?
Thank you.
Re: make a figure not selectable/movable/resizable [message #140032 is a reply to message #59522] |
Fri, 25 June 2004 09:22  |
Originally posted by: brian.fernandes.codito.com
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b18usp$2b2$1@rogue.oti.com...
> I think we need to add:
> interface EditPart {
> boolean isSelectable();
> And then change all tools, etc to look at this method. Changing just the
> selection tool does not fix the Marquee tool. Fixing the Marquee tool
does
> not fix KeyboardNavigation, etc.
> BTW, if this part appears in the OutlineView, there is no way to prevent
the
> native tree from selecting it. But, I am pretty sure that such EditParts
> would be filtered from an outline.
I'm afraid I have this problem -
I have an model A, which cannot exist without a particular child, say model
B. I have 2 separate models, because A can have other children besides B
(but it MUST have B).
I don't want B to be selectable, because all it's properties are defined by
A. Also, selecting B seperately from A is slightly confusing for someone who
knows the relationship between the two models.
I have achieved this in the Editor by having isSelectable return false.
However, the outline view still allows me to select B. I do need to show B
in the outline view - because it might have children of it's own, and it's
parent A might have other children besides B.
As you mentioned above, selecting it in the outline view selects it in the
graph. Can you suggest anything I can do to prevent this from happening ?
Obviously, I don't mind not being able to select B in the outline view
either.
Brian.
FUDForum. Page generated in 0.09876 seconds
