Home » Language IDEs » PHP Development Tools (PDT) » PDT on 64bit machine?
PDT on 64bit machine? [message #56355] Tue, 02 October 2007 03:02 Go to next message
Originally posted by: ae.brainguide.com
Hello all,
anyone experiences with PDT on 64bit machines?? Startup seems veeeeeery
slow to me! The "building PHP projects..." task takes a lot of time at
startup (about 2-3 seconds for parsing one file!).
Is there a special version to be used on 64bit?
I'm using Ubuntu 7.04, Athlon 64 Dual Core cpu, 4 GB of RAM.
thx in advance!
Re: PDT on 64bit machine? [message #56934 is a reply to message #56355] Thu, 04 October 2007 09:58 Go to previous messageGo to next message
Originally posted by: piotr.nastaly.onet.pl
Arthur Erdös wrote:
> Hello all,
> thx in advance!
There are no currently available official linux 64bit eclipse builds.
Although there once was a 64bit version of PDT, I'm not sure if it was
official or was it made by someone else. I have used it and it worked ok.
However debugging support was not working there.
If your Eclipse works slow, check your Java environment.
Make sure you got Java from Sun, and that it's version 1.5+.
In my case, going to Java 1.5.8 reduced memory usage about 10x...
If you use 32bit build of Eclipse, use also 32bit Java. There is a
possibility that your distro does not provide that in default install.
If this does not help, check you log ({your_workspace_dir}/.metadata/.log),
you might find some clues there.
Re: PDT on 64bit machine? [message #57566 is a reply to message #56934] Wed, 10 October 2007 02:37 Go to previous message
Eh, what?
All builds for all platforms:
http://www.gtlib.gatech.edu/pub/eclipse/eclipse/downloads/dr ops/R-3.3.1-200709211145/index.php#EclipseSDK
Linux 64-bit:
http://www.gtlib.gatech.edu/pub/eclipse/eclipse/downloads/dr ops/R-3.3.1-200709211145/download.php?dropFile=eclipse-SDK-3 .3.1-linux-gtk-x86_64.tar.gz
They are sdk's so probably larger in size.
Previous Topic:HTML templates in HEREDOC
Next Topic:XDebug Profiling Visualization
Current Time: Sat Aug 23 02:50:39 EDT 2025
Powered by FUDForum. Page generated in 0.03569 seconds
