Home » Language IDEs » C / C++ IDE (CDT) » makefile
makefile [message #56354] Thu, 02 January 2003 20:24 Go to next message
Originally posted by: katia.vivax-tech.com
Hi to All,
I have an error in my makefile which is like this:
objects = hello.o tpl2doc.o
hello : $(objects)
gcc -o hello $(objects) -L /usr/bin/gcc -lstdc++
gcc -o tpl2doc $(objects) -L /usr/bin/gcc -lstdc++
$(objects) : hello.cpp tpldoc.cpp
gcc -c hello.cpp
gcc -c tpl2doc.cpp
all :
${MAKE} hello
PHONY : clean
clean :
-del hello.exe $(objects)
-del tpl2doc.exe $(objects)
I did not find documentation how to write a good makefile for eclipse for
more than one cpp file. Can somebody point out my error, or provide a URL
with info?
Any Help will be gratly appreciated !
Re: makefile [message #56422 is a reply to message #56354] Fri, 03 January 2003 07:38 Go to previous messageGo to next message
Originally posted by: bud_s2460.hotmail.com
Hi Kate,
I'm no expert on make but maybe i can give you a shove in the right
direction ;)
You dont mention wether you are using linux or windows.
Some general issues I can see are that:
> hello : $(objects)
should be:
hello : $(objects)
gcc -o hello hello.o -L /usr/bin/gcc -lstdc++
gcc -o tpl2doc tpl2doc.o -L /usr/bin/gcc -lstdc++
and:
> gcc -c hello.cpp
> gcc -c tpl2doc.cpp
should be:
hello.o : hello.cpp
gcc -c hello.cpp
tpl2doc.o : tpldoc.cpp
gcc -c tpl2doc.cpp
and
> PHONY : clean
> clean :
should be:
..PHONY : clean
clean :
-del hello.exe tpl2doc.exe $(objects)
==== linux specific ===========
If you are using linux:
double check the path to gcc is correct in the -L switch ("find -type
f -name *gcc* -print" should help you locate the right location)
change -del to -rm in the clean section
remove the .exe extension from hello.exe and tpl2doc.exe in the clean
section.
======end linux specific======
==== win specific ===========
If you are using windows I found that I had to do a bit of fiddling to get
it all working.
The following works well for me in win2k - there may be a better way tho ;)
First add the path to the bin directory of MinGW to your system PATH (right
click on My Computer>properties>advanced>enviromentvariables).
Modify the:
to:
gcc -o hello hello.o -lstdc++
gcc -o tpl2doc tpl2doc.o -lstdc++
Then make a batch file in your project directory called make.bat with the
contents.:
mingw32-make -f makefile %1 %2
In eclipse in the C++ projects view right click your
project>properties>c/c++ project then uncheck the use default build command
and type make.bat in the box.
==== end win specific ===========
Go through the whole make file and make sure that you have used a single tab
to indent the required lines as make is exteremly fussy about this. When you
have done it save the project.
Now try to rebuild the project, if it doesnt work or if it does but you want
to know why you may want to have a look at
http://www.gnu.org/manual/make/html_mono/make.html#SEC_Conte nts
hf
BuD
"Kate" <katia@vivax-tech.com> wrote in message
news:av2op2$4r5$1@rogue.oti.com...
> Hi to All,
> hello : $(objects)
> gcc -c hello.cpp
> gcc -c tpl2doc.cpp
> all :
> ${MAKE} hello
> PHONY : clean
> clean :
> with info?
Re: makefile [message #56449 is a reply to message #56422] Fri, 03 January 2003 07:43 Go to previous messageGo to next message
oops - correction:
> PHONY : clean
> clean :
should be:
..PHONY : clean
clean :
;) BuD
"BuD" <bud_s2460@hotmail.com> wrote in message
news:av3vd2$lrk$1@rogue.oti.com...
> Hi Kate,
> direction ;)
> > hello : $(objects)
> should be:
> hello : $(objects)
> and:
> > gcc -c hello.cpp
> > gcc -c tpl2doc.cpp
> should be:
> hello.o : hello.cpp
> gcc -c hello.cpp
> gcc -c tpl2doc.cpp
> and
> > PHONY : clean
> > clean :
> should be:
> .PHONY : clean
> clean :
> section.
> it all working.
(right
> Modify the:
> to:
> contents.:
command
tab
you
want
> hf
> BuD
> > Hi to All,
> > hello : $(objects)
> > gcc -c hello.cpp
> > gcc -c tpl2doc.cpp
> > all :
> > ${MAKE} hello
> > PHONY : clean
> > clean :
for
URL
> > with info?
Re: makefile [message #56587 is a reply to message #56449] Fri, 03 January 2003 16:08 Go to previous message
Thanks for the answer !
This is my first encounter with non-automaticly generated makefile, so it
was very helpfull. I am using linux, but got the makefile from windows FAQ
for CDT
(none available for linux) so that why is: del hello.exe :) my mistake.
BuD wrote:
clean
> > clean :
> should be:
> ..PHONY : clean
> clean :
> ;) BuD
> > Hi Kate,
> > direction ;)
> > > hello : $(objects)
> > should be:
> > hello : $(objects)
> > and:
> > > gcc -c hello.cpp
> > > gcc -c tpl2doc.cpp
> > should be:
> > hello.o : hello.cpp
> > gcc -c hello.cpp
> > gcc -c tpl2doc.cpp
> > and
> > > PHONY : clean
> > > clean :
> > should be:
> > .PHONY : clean
> > clean :
> > section.
> > it all working.
> (right
> > Modify the:
> > to:
> > contents.:
> command
> tab
> you
> want
> > hf
> > BuD
> > > Hi to All,
> > > hello : $(objects)
> > > gcc -c hello.cpp
> > > gcc -c tpl2doc.cpp
> > > all :
> > > ${MAKE} hello
> > > PHONY : clean
> > > clean :
> for
> URL
> > > with info?
Previous Topic:problem with step over debugging
Next Topic:scrollbars of the Editor and Outline window do not work
Current Time: Wed Nov 05 16:14:07 EST 2025
Powered by FUDForum. Page generated in 0.09033 seconds
