Home » Language IDEs » AspectJ » Adding an interace to class based on it implementing a interface.
Adding an interace to class based on it implementing a interface. [message #56321] Wed, 31 August 2005 14:04 Go to next message
Is it possibly to create a static crosscut that says "any class implementing
interface X, implements interace Y as well".
class Foo implements X
public aspect ImplementY {
declare parents : X extends Y;
The above changes X to implement Y, when I only want Foo to implement Y.
Using implements instaed of extends makes no different either.
Re: Adding an interace to class based on it implementing a interface. [message #56346 is a reply to message #56321] Wed, 31 August 2005 14:58 Go to previous messageGo to next message
Yes, the trick is to write a type pattern that matches subtypes
(implementors) of X, but not X itself.
declare parents: (X+ && !X) implements Y;
should do the trick.
Regards, Adrian.
Re: Adding an interace to class based on it implementing a interface. [message #56385 is a reply to message #56346] Thu, 01 September 2005 13:40 Go to previous message
Yup. Figured that out late last night. Thx for the reply.
"Adrian Colyer" <adrian_colyer@uk.ibm.com> wrote in message
news:df4uk0$tut$1@news.eclipse.org...
implementing
> Regards, Adrian.
Re: Adding an interace to class based on it implementing a interface. [message #589969 is a reply to message #56321] Wed, 31 August 2005 14:58 Go to previous message
Regards, Adrian.
Re: Adding an interace to class based on it implementing a interface. [message #589982 is a reply to message #56346] Thu, 01 September 2005 13:40 Go to previous message
implementing
> Regards, Adrian.
Previous Topic:ClassFormatError
Next Topic:AJDT New Feature of the Week: Navigation and source hovers for pointcuts
Current Time: Fri Nov 07 19:51:09 EST 2025
Powered by FUDForum. Page generated in 0.03719 seconds
