| Just trying to get Hello World to work [message #56304] |
Fri, 22 April 2005 16:27  |
Originally posted by: stan.ccpu.com
Hi everyone,
I'm trying to get up and running with Eclipse 3.0. I've tried the Hello
World plug-in tutorial several times, including doing it the slow way as
shown in the JDG2E book, and the quick way using the Hello World plug-in
template. Everything appears fine in plugin.xml and the java classes. I
run it with
Run -> Run As -> Runtime Workbench. The 'Select Configuration' dialog
comes up, and I've tried selecting both 'New_configuration(1)' and
'Run-time Workbench'. The workbench comes up, but there is no 'Sample
Menu' with 'Sample Action'. I select 'Windows -> Customize Perspective'
and looked in the list of commands, but there is no command for 'Sample
Action'. I tried scrolling through all the listed commands, and no
'Sample...' appeared in the menubar or toolbar details. This ought to just
work, right? Any ideas?
Thanks very much,
Stan Stringfellow
| Re: Just trying to get Hello World to work [message #57247 is a reply to message #56304] |
Mon, 25 April 2005 20:02  |
Originally posted by: Chris_Laffra.ca.ibm.com
Have you tried "Reset Perspective"? Otherwise, the log may have some
information.
See http://www.eclipsefaq.org/chris/faq/html/faq27.html
Chris Laffra, http://eclipsefaq.org
"Stan Stringfellow" <stan@ccpu.com> wrote in message
news:d51b810913fecb1b4852abcce2ca7e66$1@www.eclipse.org...
> Hi everyone,
> run it with
> Thanks very much,
> Stan Stringfellow
FUDForum. Page generated in 0.08635 seconds
