Home » Newcomers » Newcomers » Just trying to get Hello World to work
Just trying to get Hello World to work [message #56304] Fri, 22 April 2005 16:27 Go to next message
Originally posted by: stan.ccpu.com
Hi everyone,
I'm trying to get up and running with Eclipse 3.0. I've tried the Hello
World plug-in tutorial several times, including doing it the slow way as
shown in the JDG2E book, and the quick way using the Hello World plug-in
template. Everything appears fine in plugin.xml and the java classes. I
run it with
Run -> Run As -> Runtime Workbench. The 'Select Configuration' dialog
comes up, and I've tried selecting both 'New_configuration(1)' and
'Run-time Workbench'. The workbench comes up, but there is no 'Sample
Menu' with 'Sample Action'. I select 'Windows -> Customize Perspective'
and looked in the list of commands, but there is no command for 'Sample
Action'. I tried scrolling through all the listed commands, and no
'Sample...' appeared in the menubar or toolbar details. This ought to just
work, right? Any ideas?
Thanks very much,
Stan Stringfellow
Re: Just trying to get Hello World to work [message #57247 is a reply to message #56304] Mon, 25 April 2005 20:02 Go to previous message
Originally posted by: Chris_Laffra.ca.ibm.com
Have you tried "Reset Perspective"? Otherwise, the log may have some
information.
See http://www.eclipsefaq.org/chris/faq/html/faq27.html
Chris Laffra, http://eclipsefaq.org
"Stan Stringfellow" <stan@ccpu.com> wrote in message
news:d51b810913fecb1b4852abcce2ca7e66$1@www.eclipse.org...
> Hi everyone,
> run it with
> Thanks very much,
> Stan Stringfellow
Previous Topic:Eclipse 3.1
Next Topic:Java Perspective Not working
Current Time: Mon Sep 01 00:55:34 EDT 2025
Powered by FUDForum. Page generated in 0.05541 seconds
