Home » Language IDEs » PHP Development Tools (PDT) » type hinting for arrays
type hinting for arrays [message #56203] Mon, 01 October 2007 08:30 Go to next message
hey folks,
i'm not sure if this has been requested before, but it would be great if pdt would recognize objects
returned in an array:
class Foo {
public $var1;
* returns an array of Foo objects
* @return Foo[] array of Foo objects
public static getInstances() {
return array(new Foo(), new Foo());
foreach (Foo::getInstances() as $foo) {
$foo->var1 = "bar"; // after $foo->, ctrl+space will display $var1
when returning a single object, pdt parses the phpdoc and everything works great, but here we have
an array, so pdt had to parse through the code ("foreach") as well, in order to apply the correct
object type to the variable $foo.
is that even possible? that would make pdt even greater than it already is! :)
cheers,
-nico.
Re: type hinting for arrays [message #56325 is a reply to message #56203] Mon, 01 October 2007 22:03 Go to previous messageGo to next message
Bug 170968 – Use PHPDoc hints for arrays of objects
https://bugs.eclipse.org/bugs/show_bug.cgi?id=170968
Re: type hinting for arrays [message #56378 is a reply to message #56325] Tue, 02 October 2007 04:23 Go to previous message
Toshihiro wrote:
> Bug 170968 � Use PHPDoc hints for arrays of objects
right, thanks for pointing that out, i wasnt sure if it was already taken care of.
cheers
Previous Topic:PHP Filename illigal characters
Next Topic:XDebug and Breakpoints
Current Time: Tue Jul 22 12:04:37 EDT 2025
Powered by FUDForum. Page generated in 0.05775 seconds
