Home » Eclipse Projects » Remote Application Platform (RAP) » Theme can't be registered
Theme can't be registered [message #56178] Mon, 29 October 2007 07:56 Go to next message
Hi!
I'm trying to use theming, but when i start the OSGi Framework i get the
following message:
Could not register SWT theme 'themeID' from file
'theme1/theme.properties'. Reason: null
The theme is the one from the demo (it works fine there). I copied the
folder to my plug in and changed the id.
Here is the XML from the plugin.xml:
<extension point="org.eclipse.rap.ui.themes">
<theme
file="theme1/theme.properties"
id="themeID"
name="MyTheme">
</theme>
</extension>
I also tried to create my own theme (based on the template in
org.eclipse.rap.rwt), but i get the same error.
Any ideas?
Magnus
Re: Theme can't be registered [message #56199 is a reply to message #56178] Mon, 29 October 2007 10:23 Go to previous message
Hm, it works now, but i can't reproduce the problem... I played around
with the runtime classpath and the build configuration, but i don't know
what caused the problem...
Magnus
Magnus Konze schrieb:
> Hi!
> following message:
> <theme
> id="themeID"
> name="MyTheme">
> </theme>
> </extension>
> Any ideas?
> Regards
> Magnus
Previous Topic:RAP applications under JDK 5
Next Topic:Preference dialog question
Current Time: Sat Nov 15 21:55:10 EST 2025
Powered by FUDForum. Page generated in 0.04646 seconds
