Home » Archived » XML Schema Definition (XSD) » JAXB - compiling schema
JAXB - compiling schema [message #56151] Thu, 09 December 2004 15:01 Go to next message
Originally posted by: ronball.mho.com
Other than executing an Ant build, can you compile the schema inside
Eclipse?
Re: JAXB - compiling schema [message #56174 is a reply to message #56151] Fri, 10 December 2004 06:14 Go to previous message
Ron,
Is your question specifically about JAXB, which has nothing to do with
this project, or are you asking about EMF's XML Schema to Ecore
conversion from which you can generate a JAXB-like Java implementation
of your schema's model? We have command line tools for those that you
can invoke programmatically...
> Eclipse?
Re: JAXB - compiling schema [message #593175 is a reply to message #56151] Fri, 10 December 2004 06:14 Go to previous message
Ron,
> Eclipse?
Previous Topic:JAXB - compiling schema
Next Topic:Resolving a basetype reference in a different schema.
Current Time: Mon Nov 10 05:05:38 EST 2025
Powered by FUDForum. Page generated in 0.48881 seconds
