Home » Eclipse Projects » Mylyn » How does the commit message get filled in automatically?
How does the commit message get filled in automatically? [message #56118] Fri, 15 August 2008 13:12 Go to next message
I'm using mylyn 3.0.1, eclipse 3.4, with bugzilla/CVS.
I have activated a bug and activated a few files with that bug, they
show up correctly in the project explorer. But when I go to commit
them, no commit message is present.
The Tasks -> Team Automatically create and manage with task content is on.
And in Team -> CVS -> Sync, I specify:
Allow models to participate...
Automatically enable change set grouping in CVS sync (I tried this
both ways)
Francis
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: How does the commit message get filled in automatically? [message #56167 is a reply to message #56118] Sun, 17 August 2008 19:21 Go to previous messageGo to next message
Originally posted by: steffen.pingel.eclipse.org
Have you tried using the synchronize view? If you create a synchronization
for your CVS projects your outgoing changes should be grouped by change
sets. Also make sure you have a commit comment template set under Tasks >
Team, e.g. "${task.status} - ${connector.task.prefix} ${task.key}:
${task.description}".
If you select commit from the synchronize view the commit comment should be
automatically filled in.
If that does not work, please install the latest build from the weekly
update site and file a bug if the problem persists:
http://www.eclipse.org/mylyn/downloads/
Thanks.
Steffen
> both ways)
> Francis
Re: How does the commit message get filled in automatically? [message #56298 is a reply to message #56167] Wed, 20 August 2008 11:42 Go to previous messageGo to next message
Yes, I use the synchronize view, but the change sets don't appear
automatically. I have to create the change set and then manually put in
the bug information for them.
There must be something I'm missing about how to get the change sets
automatically created from my bug report. Can you help with that?
> Thanks.
> Steffen
>> both ways)
>> Thanks,
>> Francis
Re: How does the commit message get filled in automatically? [message #56306 is a reply to message #56298] Wed, 20 August 2008 15:34 Go to previous messageGo to next message
Can you check if Mylyn Tasks UI and Mylyn Team UI are enabled under General
> Startup and Shutdown in the Eclipse preferences? The team startup is
required to register Mylyn's change set management.
Steffen
>> synchronization for your CVS projects your outgoing changes should be
>> grouped by change sets. Also make sure you have a commit comment template
>> set under Tasks > Team, e.g. "${task.status} - ${connector.task.prefix}
>> ${task.key}: ${task.description}".
>> be automatically filled in.
>> Thanks.
>> Steffen
>>> on.
>>> both ways)
>>> Thanks,
>>> Francis
Re: How does the commit message get filled in automatically? [message #56318 is a reply to message #56306] Wed, 20 August 2008 20:50 Go to previous messageGo to next message
Yes, they are both enabled, I did not have to enable them.
> Steffen
>>> Thanks.
>>> Steffen
>>>> on.
>>>> both ways)
>>>> Thanks,
>>>> Francis
Re: How does the commit message get filled in automatically? [message #56336 is a reply to message #56318] Wed, 20 August 2008 22:11 Go to previous messageGo to next message
Just to make sure: Do you have the presentation in the Synchronize View set
to "Change Sets" (the default is "All Models")? Are there any errors in the
error log?
If you haven't done so already I would recommend to update to the latest
Mylyn 3.0.2 weekly build which has some improvements for the change set
management.
Steffen
>> General
>> Steffen
>>>> template set under Tasks > Team, e.g. "${task.status} -
>>>> ${connector.task.prefix} ${task.key}: ${task.description}".
>>>> should be automatically filled in.
>>>> Thanks.
>>>> Steffen
>>>>> on.
>>>>> both ways)
>>>>> Thanks,
>>>>> Francis
Re: How does the commit message get filled in automatically? [message #56352 is a reply to message #56336] Wed, 20 August 2008 22:19 Go to previous messageGo to next message
Francis, this FAQ entry summaries trouble shooting steps to get change sets
working:
http://wiki.eclipse.org/Mylyn/FAQ#Why_does_task_change_set_n ot_appear_when_I_modify_files.3F
If that does not resolve the problem, please file a bug report:
Steffen
Re: How does the commit message get filled in automatically? [message #56501 is a reply to message #56352] Sun, 24 August 2008 23:17 Go to previous message
Thank you Steffen and sorry to waste your time. I did not have the
Eclipse IDE connector installed. Once I installed that everything
worked amazingly well.
Francis
> working:
> Steffen
Re: How does the commit message get filled in automatically? [message #592515 is a reply to message #56118] Sun, 17 August 2008 19:21 Go to previous message
Thanks.
Steffen
> both ways)
> Francis
Re: How does the commit message get filled in automatically? [message #592610 is a reply to message #56167] Wed, 20 August 2008 11:42 Go to previous message
> Thanks.
> Steffen
>> both ways)
>> Thanks,
>> Francis
Re: How does the commit message get filled in automatically? [message #592614 is a reply to message #56298] Wed, 20 August 2008 15:34 Go to previous message
Steffen
>> Thanks.
>> Steffen
>>> on.
>>> both ways)
>>> Thanks,
>>> Francis
Re: How does the commit message get filled in automatically? [message #592621 is a reply to message #56306] Wed, 20 August 2008 20:50 Go to previous message
> Steffen
>>> Thanks.
>>> Steffen
>>>> on.
>>>> both ways)
>>>> Thanks,
>>>> Francis
Re: How does the commit message get filled in automatically? [message #592628 is a reply to message #56318] Wed, 20 August 2008 22:11 Go to previous message
error log?
management.
Steffen
>> General
>> Steffen
>>>> Thanks.
>>>> Steffen
>>>>> on.
>>>>> both ways)
>>>>> Thanks,
>>>>> Francis
Re: How does the commit message get filled in automatically? [message #592638 is a reply to message #56336] Wed, 20 August 2008 22:19 Go to previous message
working:
Steffen
Re: How does the commit message get filled in automatically? [message #592701 is a reply to message #56352] Sun, 24 August 2008 23:17 Go to previous message
Francis
> working:
> Steffen
Previous Topic:Open source task repository
Next Topic:Missing News & Noteworthy for weekly builds
Current Time: Sat Aug 09 02:13:12 EDT 2025
Powered by FUDForum. Page generated in 0.06616 seconds
