Home » Eclipse Projects » Remote Application Platform (RAP) » RAP applications under JDK 5
RAP applications under JDK 5 [message #56078] Mon, 29 October 2007 05:50 Go to next message
Originally posted by: andreasruempel.gmx.net
I wanted to test my RAP application using JDK 5, but it says that the
entry point does not exist. Under JDK 6 it works fine. The same problem
occurs with a fresh wizard-generated simple RAP application with one view.
Any comments?
Andi
Re: RAP applications under JDK 5 [message #56386 is a reply to message #56078] Mon, 29 October 2007 13:58 Go to previous message
Originally posted by: jkrause.innoopract.com
This is very likely a problem with your compiler settings (check the
your preferences). RAP works with JDK 1.4, 5.0 and 6.0.
Andreas Rümpel wrote:
> Any comments?
> Regards
> Andi
Previous Topic:Deny access to one TabItem in a TabFolder
Next Topic:Theme can't be registered
Current Time: Sat Nov 08 00:04:28 EST 2025
Powered by FUDForum. Page generated in 0.03792 seconds
