Home » Language IDEs » AspectJ » Parameterized vararg match problem
Parameterized vararg match problem [message #56077] Sat, 27 August 2005 21:44 Go to next message
The pointcut in the example below is not applied.
public class Test1<E> {
public void method1(E...args) {
public aspect TestAspect {
after(Test1 test1, Object[] arg) returning: execution(*
Test1.method1(Object...)) && target(test1) && args(arg) {
System.out.println("got here");
If I remove vararg from the pointcut declaration (below) then the pointcut
is applied ok.
after(Test1 test1) returning: execution(* Test1.method1(Object...)) &&
target(test1) {
Is there something wrong with the declaration or is it a bug?
I am using AJDT M3.
Roman
Re: Parameterized vararg match problem [message #56157 is a reply to message #56077] Tue, 30 August 2005 12:37 Go to previous messageGo to next message
Originally posted by: adrian_colyer.uk.ibm.com
Roman Kishchenko wrote:
I confirm I can reproduce this bug. It only occurs when the vararg type
is a type parameter (ie. if you change the definition of method1 to take
an (Object... args) parameter then the matching works as expected.
Please raise a bug report and I'll get this fixed for you.
Thks, Adrian.
Re: Parameterized vararg match problem [message #56311 is a reply to message #56157] Tue, 30 August 2005 20:19 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=108437
Roman
"Adrian Colyer" <adrian_colyer@uk.ibm.com> wrote in message
news:df220a$b4h$1@news.eclipse.org...
> I confirm I can reproduce this bug. It only occurs when the vararg type is
> a type parameter (ie. if you change the definition of method1 to take an
> Thks, Adrian.
Re: Parameterized vararg match problem [message #589937 is a reply to message #56077] Tue, 30 August 2005 12:37 Go to previous message
Thks, Adrian.
Re: Parameterized vararg match problem [message #589954 is a reply to message #56157] Tue, 30 August 2005 20:19 Go to previous message
Roman
> Thks, Adrian.
Previous Topic:ClassFormatError
Next Topic:Adding an interace to class based on it implementing a interface.
Current Time: Mon Jul 21 20:02:48 EDT 2025
Powered by FUDForum. Page generated in 0.04469 seconds
