Home » Archived » XML Schema Definition (XSD) » choice or sequence min/max occurs
choice or sequence min/max occurs [message #55964] Mon, 06 December 2004 17:09 Go to next message
Originally posted by: rob.tice.k-int.com
Apologies if this is a trivial problem I just cant see how to get the info.
I am traversing a schema and I have got to the point where I have my XSD
model group. I am using the model group getContents() to traverse the
elements all working okay schema analysis working. However I also need to
know what each choice or sequence has as it min/max occurs so I can properly
understand the relative min/max occurs of the contained elements.
Any help much appreciated.
Rob Tice
Re: choice or sequence min/max occurs [message #56017 is a reply to message #55964] Mon, 06 December 2004 18:08 Go to previous messageGo to next message
Rob,
An XSDModelGroup is reached from an XSDParticle, and that is what holds
the min/max occurs. The same model group could be reached by multiple
particles, as for a model group in model group definition that has a
different min/max occurs at each point of reference. So don't expect to
be able to work back from an element declaration or model group to the
particle that references it, since there isn't a unique answer (although
often it will be just the container).
>Rob Tice
Re: choice or sequence min/max occurs [message #56070 is a reply to message #56017] Mon, 06 December 2004 19:50 Go to previous message
Thanks Ed
Problem solved
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:cp2opq$osv$1@www.eclipse.org...
> Rob,
info.
properly
> >Rob Tice
Re: choice or sequence min/max occurs [message #593082 is a reply to message #55964] Mon, 06 December 2004 18:08 Go to previous message
Rob,
>Rob Tice
Re: choice or sequence min/max occurs [message #593113 is a reply to message #56017] Mon, 06 December 2004 19:50 Go to previous message
Thanks Ed
Problem solved
> Rob,
info.
properly
> >Rob Tice
Previous Topic:XML <-> ASN.1 : Developer response?
Next Topic:min/max Occurs
Current Time: Mon Sep 01 02:32:14 EDT 2025
Powered by FUDForum. Page generated in 0.03457 seconds
