Home » Language IDEs » PHP Development Tools (PDT) » create_function and step-into (xdebug)
create_function and step-into (xdebug) [message #55914] Fri, 28 September 2007 18:50 Go to next message
Debug the the below breaking at the fist line:
<?php
$newfunc = create_function('$a,$b', 'return "Avarage=" . ($a+$b)/2;');
echo "functio name: $newfunc\n";
echo $newfunc(7,5) . "\n";
Now if you reach the 3rd line and try to "step into" it to execute the
anonymous function, the debugger would give you an error stating that it
cannot reach the file where the function exists, which osofcourse normal
since there is not file where this function is defined.
I don't know if this would be a bug or just a new feature (new feature
is more like it). Would it be possible to disable the "step into" button
when reaching lines that contain such calls? Or at least, give a more
informative error message?
Ali
Re: create_function and step-into (xdebug) [message #55975 is a reply to message #55914] Sat, 29 September 2007 07:42 Go to previous messageGo to next message
Originally posted by: Martin.eisengardt.de
IMHO this is a bug. Stepping into dynamic functions/ eval would be nice but
I think it is not possible inside PDT. Because create function compiles this
code and the debugger does not have any source file it could start with.
Source can be located in some strings read from database. The only way is to
display disassembly (zend opcodes). That would be a nice feature at all ;-)
> Would it be possible to disable the "step into" button when reaching lines
Disabling would be nice or simply step over instead of displaying any error
message. Eclipse (JDT with native functions and PDT with built in or c
methods) already ignores every step into non debuggable code.
Re: create_function and step-into (xdebug) [message #56030 is a reply to message #55914] Sun, 30 September 2007 09:40 Go to previous messageGo to next message
I doubt it would be possible to disable the step into button, as there is no
way to know the behaviour of the next line to be executed (the wonders of
a dynamic language). A better message could be displayed of course but it would
be generic for all scenarios where source could not be located.
On the whole though this doesn't really detract from the debug experience. It is
telling you that the source cannot be located and there is indication in the
extra stack frame created by PHP as well. You can always press F7 (Step return) to
jump out of the method/function that doesn't have any source.
This is what happens in java as well if you enter a method where there is no source
available for the class.
Dave Kelsey
> <?php
> Cheers,
> Ali
Re: create_function and step-into (xdebug) [message #56057 is a reply to message #55914] Sun, 30 September 2007 11:54 Go to previous messageGo to next message
Originally posted by: dkel50.hotnospmail.com
Sorry, forgot to add, to get the message improved you will need to raise
a bugzilla about it and quote the example you gave in the append to show
how it doesn't cover this.
Cheers
Dave Kelsey
> <?php
> Cheers,
> Ali
Re: create_function and step-into (xdebug) [message #56082 is a reply to message #56057] Sun, 30 September 2007 16:31 Go to previous messageGo to next message
Dave,
Thanks. But can't it just handles this case the same way it does to
bultin functions for example (as Martin suggested)?
Ali
> Cheers
> Dave Kelsey
>> <?php
>> it cannot reach the file where the function exists, which osofcourse
>> normal since there is not file where this function is defined.
>> button when reaching lines that contain such calls? Or at least, give
>> a more informative error message?
>> Cheers,
>> Ali
Re: create_function and step-into (xdebug) [message #56182 is a reply to message #56082] Mon, 01 October 2007 06:21 Go to previous messageGo to next message
It would not be possible to gray out the step into buttons (note they aren't grayed out
when you are about to execute a built-in or extension function). As built-in
and extension functions are c code, not php, xdebug won't be able to interrupt
the execution of them (so to xdebug these are atomic). PDT won't know what the next
line will do, even PHP doesn't know what the next line will do until it actually
executes it so PHP+Xdebug isn't able to tell PDT that the next line should not
support step into.
As you have created an anonymous php function which can be interrupted
by xdebug it will be able to step into it like any other function. Xdebug would have to
be to determine it was in an anonymous function and to not allow stepping
into it (a step_into request would be interpreted as step_over). There isn't anything
PDT can do about this except provide a better error message.
You could try raising an enhancement on xdebug itself at http://www.xdebug.org which
would then have some sort of configurable option to allow it to behave the way you want, then
it will be upto Derick to assess the feasibility of this.
Cheers
Dave Kelsey
Ali B. wrote:
> Dave,
> Cheers,
> Ali
>> show how it doesn't cover this.
>> Cheers
>> Dave Kelsey
>>> <?php
>>> the anonymous function, the debugger would give you an error stating
>>> that it cannot reach the file where the function exists, which
>>> osofcourse normal since there is not file where this function is
>>> defined.
>>> feature is more like it). Would it be possible to disable the "step
>>> into" button when reaching lines that contain such calls? Or at
>>> least, give a more informative error message?
>>> Cheers,
>>> Ali
Re: create_function and step-into (xdebug) [message #56254 is a reply to message #56182] Mon, 01 October 2007 09:14 Go to previous message
Dave,
You made that crystal clear.. Thanks.
Cheers
Ali
> aren't grayed out
> built-in
> interrupt
> what the next
> actually
> should not
> support step into.
> isn't anything
> Cheers
> Dave Kelsey
> Ali B. wrote:
>> Dave,
>> Cheers,
>> Ali
>>> Cheers
>>> Dave Kelsey
>>>> <?php
>>>> defined.
>>>> Cheers,
>>>> Ali
Previous Topic:debug fails when stepping into included file
Next Topic:Where is PDT's preferences file? - Regards Bug #204525
Current Time: Mon Nov 03 18:11:16 EST 2025
Powered by FUDForum. Page generated in 0.04849 seconds
