| RAServer : error in console [message #55913] |
Wed, 01 March 2006 10:43 |
Originally posted by: schausson.genigraph.fr
Hi all,
I've just downloaded TPTP 4.2.0 (ALL) and Agent Controller V4.2.0 (Win).
I've launched the setConfig.bat in the Agent Controller bin directory to
generate the configuration file and started the agent controller (as an
application), by using RAServer.exe.
I actually don't know if it works fine, because nothing is displayed in
the console of RAServer.
The problem is that when I try to launch an automatic recorded test suite
(created using AGR) from my eclipse workbench, I'm getting the stack below
in the command prompt of RAServer. Moreover, the launcher stalls (around
60%) and hangs up, using 100% CPU...
Has anybody already faced this issue ?
Many thanks,
Sebastien
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/IProgressMonitor
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Unknown Source)
at java.lang.Class.getDeclaredMethod(Unknown Source)
org.eclipse.hyades.internal.collection.framework.FileClientH andlerExtendedImpl.executeCommand(FileClientHandlerExtendedI mpl.java:126)
org.eclipse.hyades.internal.collection.framework.FileClientH andlerExtendedImpl.run(FileClientHandlerExtendedImpl.java:27 2)
at java.lang.Thread.run(Unknown Source)
FUDForum. Page generated in 0.03205 seconds
