Home » Eclipse Projects » Plugin Development Environment (PDE) » Invalid access restriction error?
Invalid access restriction error? [message #55883] Thu, 16 April 2009 10:50 Go to next message
We have an 'Access restriction' error we are getting from PDE which seems
invalid but I wanted to ask here before opening a bug. This is the
scenario:
1) plugin.x has two classes, pluginx.B and pluginx.internal.A. plugin.x is
exporting the package pluginx to the runtime, but it is not exporting the
internal package. This is what pluginx/internal/A.java looks like:
package pluginx.internal;
public class A {
public A() {
public void init() {
This is what pluginx/B.java looks like:
package pluginx;
import pluginx.internal.A;
public class B extends A {
public B() {
super();
2) Another plug-in, plugin.y has one class defined - pluginy.C. It imports
the 'pluginx' package from plugin.x, and looks like:
package pluginy;
import pluginx.B;
public class C extends B {
public C() {
super();
super.init();
When compiling this in the PDE tool, I get this error message:
Access restriction: The method init() from the type A is not accessible
due to restriction on required project
plugin.x C.java plugin.y/src/pluginy line 11 Java Problem
This is occurring because class 'B' is not overriding the 'init()' method
in class 'A', but I was expecting this to work without errors.
Should I open a bug?
Re: Invalid access restriction error? [message #57609 is a reply to message #55883] Tue, 21 April 2009 21:53 Go to previous message
Originally posted by: n.n.nnn
> seems invalid but I wanted to ask here before opening a bug. This is the
> scenario:
> due to restriction on required project plugin.x C.java
> method in class 'A', but I was expecting this to work without errors.
Hi Phil,
Isn't PDE just reporting what the Java compiler tells it?
Re: Invalid access restriction error? [message #596066 is a reply to message #55883] Tue, 21 April 2009 21:53 Go to previous message
> scenario:
Hi Phil,
Previous Topic:Headless RCP Product Export
Next Topic:Build updatesite doesn't create web/* and index.html
Current Time: Thu Nov 06 16:08:25 EST 2025
Powered by FUDForum. Page generated in 0.03211 seconds
