Home » Modeling » OCL » implementation for checking invalid select expressions
implementation for checking invalid select expressions [message #55874] Thu, 15 May 2008 15:09 Go to next message
Hey,
Suppose I have a Set of Integers, and call the following:
theSet->select( x | x.contains("abc"));
Which is the error that's spit out:
a) Undefined Operation "contains" for type "Integer" (the type of x is assumed
to be Integer from the context)
b) Argument { String => Boolean } cannot be applied to function select of type
"set<Integer>"?
Is this just implementation-specific? Would one speak of "type inference" in
both cases?
Felix
Re: implementation for checking invalid select expressions [message #55901 is a reply to message #55874] Thu, 15 May 2008 15:34 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Felix,
It would be hard for an OCL implementation to supply message (b)
because, as the Integer type doesn't have a "contains" operation, there
is not reason to suppose that its result value might be String.
Although, I'm not sure that I understand what you mean by
in your description.
I would generally expect something like the message (a)
HTH,
Christian
Felix Dorner wrote:
> Hey,
> assumed to be Integer from the context)
> of type "set<Integer>"?
> inference" in both cases?
> Felix
Re: implementation for checking invalid select expressions [message #55954 is a reply to message #55901] Thu, 15 May 2008 17:50 Go to previous messageGo to next message
Christian W. Damus wrote:
> Hi, Felix,
At some point during the parsing, the "x" (in the expression part) must be
assigned a type. From your response, I derive that this x is simply by
definition an "Integer", because it's used as the iterator for a set of Integers...
With {String => Boolean } I mean something like a closure (or a function),
taking a String as an argument and returning a Boolean. I somehow see
parallelities in iterator expressions and function arguments, although the OCL
specification does not mention this relationship (afaik). So select respective
collect operations for collections containing elements of type T can be seen as
functions that take arguments of type {T => Boolean}, respective {T=>V} where V
is simply "any Type", similar to generic operations.
Re: implementation for checking invalid select expressions [message #55980 is a reply to message #55954] Thu, 15 May 2008 20:19 Go to previous messageGo to next message
Hi, Felix,
I see. Yes, the type of x is, implicitly, the element type of the
source collection of the select expression. This implicit type is
explicitly defined as such by OCL :-)
I see the body expressions of iterators as more like block closures
than function objects, because they have access to the variables in
the enclosing context. Rather like Smalltalk's iteration methods on
collections.
I hope that, between us, we have answered your original question?
cW
>> Hi, Felix,
> must be assigned a type. From your response, I derive that this x is
> simply by definition an "Integer", because it's used as the iterator
> function), taking a String as an argument and returning a Boolean. I
> somehow see parallelities in iterator expressions and function
> arguments, although the OCL specification does not mention this
> relationship (afaik). So select respective collect operations for
> collections containing elements of type T can be seen as functions
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
Re: implementation for checking invalid select expressions [message #56007 is a reply to message #55980] Fri, 16 May 2008 05:40 Go to previous message
Hi Christian,
> collections.
I was imprecise, I mean exactly that.
Yes :)
Previous Topic:Problem while validating TupleLiteralParts (checkValuePart constraint)
Next Topic:Bug in OCLAbstractAnalyzer
Current Time: Thu Jul 17 22:20:03 EDT 2025
Powered by FUDForum. Page generated in 0.03624 seconds
