Home » Eclipse Projects » Mylyn » Task list empty?
| Task list empty? [message #55823] |
Mon, 11 August 2008 05:39  |
Originally posted by: renaud.denis.bsb.com
Hi *,
First, Mylyn is *huge*; thanks for your great work on it :)
Here is my problem in Mylyn 3, with JIRA extension, under Eclipse Europa
(FlexBuilder 3 to be exact):
* Task Repository filled with a JIRA repository
* "Assigned To Me" query on the JIRA repository
The connection validates well, I'm even able to "open in a browser" my
query, and the results are shown correctly in the internal web browser.
But the list remains empty, whatever I do.
I use Mylyn successfully under Eclipse Ganymede for my Java projects,
with (afaik) the same configuration, same repository, same query.
Any help would be appreciated...
Renaud
| Re: Task list empty? [message #55849 is a reply to message #55823] |
Mon, 11 August 2008 14:00   |
Is there a little warning icon on the query or an error displayed when
synchronize the query or an error in the error log?
You could try to update the repository configuration from the Task
Repositories view and then synchronize the query again. If that does not
help please file a bug:
http://eclipse.org/mylyn/bugs
Steffen
Renaud Denis wrote:
> Hi *,
> Renaud
| Re: Task list empty? [message #55957 is a reply to message #55876] |
Wed, 13 August 2008 16:56  |
Please check the setting for Max Number of Search Results in the repository
properties under Additional Settings. If that is set to "0" it would cause
no results to be displayed for your query. If that is the case please
comment on this bug report:
243849: Default repository max number of search results
https://bugs.eclipse.org/bugs/show_bug.cgi?id=243849
Steffen
Renaud Denis wrote:
> I did what you propose, but it didn't help. I can't see any warning icon
> on the query and here is the only log event I can see when trying to
> synchronize the query (in attachment).
> Looks like a keys bindings error??
>> Steffen
>> Renaud Denis wrote:
>>> Hi *,
>>> Renaud
| Re: Task list empty? [message #592389 is a reply to message #55823] |
Steffen
Renaud Denis wrote:
> Hi *,
> Renaud
| Re: Task list empty? [message #592402 is a reply to message #55849] |
Tue, 12 August 2008 05:26  |
--------------040905010505010903080601
Steffen Pingel a
| Re: Task list empty? [message #592438 is a reply to message #55876] |
Steffen
Renaud Denis wrote:
>> Steffen
>> Renaud Denis wrote:
>>> Hi *,
>>> Renaud
Current Time: Mon Oct 27 20:20:47 EDT 2025
Powered by FUDForum. Page generated in 0.08979 seconds
