Home » Archived » XML Schema Definition (XSD) » Running out of memory..
Running out of memory.. [message #55814] Thu, 02 December 2004 18:18 Go to next message
Originally posted by: Abhinav.Vohra.siebel.com
All
Whenever I load an XSD that imports more than 2 or 3 other xsds the memory
spikes. In addition, it seems like this memory isnt being freed up. Does the
XSD library store loaded XSDResource statically?
The following is a snippet of code I'm using to load my XSD. I provide the
resourceset with a custom URIConverter to handle imports.
ResourceSet resourceSet = XSDSchemaImpl.createResourceSet();
resourceSet.setURIConverter(resolver);
Resource res = resourceSet.getResource(uri, true);
Re: Running out of memory.. [message #55868 is a reply to message #55814] Fri, 03 December 2004 05:17 Go to previous message
Abhinav,
Your models are loaded into your local resource set and should last
only/just as long.
Abhinav Vohra wrote:
>All
Re: Running out of memory.. [message #592999 is a reply to message #55814] Fri, 03 December 2004 05:17 Go to previous message
Abhinav,
only/just as long.
>All
Previous Topic:XML <-> ASN.1 : Developer response?
Next Topic:choice or sequence min/max occurs
Current Time: Sun Aug 31 23:06:27 EDT 2025
Powered by FUDForum. Page generated in 0.25405 seconds
