Home » Eclipse Projects » DTP » How to grant custom ODA data source access to webapp jar files?
How to grant custom ODA data source access to webapp jar files? [message #55769] Fri, 17 April 2009 12:13
Originally posted by: shardt.troux.com
I am not sure if this is a question for the BIRT or DTP newsgroup, so I
am cross-posting here as well.
I am having a deployment issue with a custom ODA data source and would
appreciate any help.
I have implemented a custom ODA data source based on the BIRT JDBC data
source. I have deployed the data source to my webapp that has the BIRT
web viewer embedded. The data source is deployed in
WEB-INF/platform/plugins. This data source uses class files that are
located in jar files in the WEB-INF/lib directory.
When I launch a report that uses the data source, I get a
java.lang.NoClassDefFoundError on the classes that are located in the
WEB-INF/lib directory. The data source needs access to the class
instances loaded by the webapp classloader.
How can I grant the data source access to the webapp class instances?
Any help is appreciated.
Environment:
BIRT 2.3.2
Tomcat 5.5
Shannon
Previous Topic:generate entities problem with sql server
Next Topic:How to grant custom ODA data source access to webapp jar files?
Current Time: Tue Dec 02 04:50:18 EST 2025
Powered by FUDForum. Page generated in 0.03353 seconds
