| Node -> XSDConcreteComponent [message #55758] |
Wed, 01 December 2004 08:20  |
Originally posted by: runinpanic.gmx.de
I wish to find the corresponding XSDConcreteComponent-Object to a given
Node.
I have a XSDConcreteComponent and an XPath-Expression to get the node:
private void whatever(XSDConcreteComponent context, String xpath) {
Element root = context.getElement();
Node schemaNode = XPathAPI.selectSingleNode(root, xpath);
Now I need the XSDConcreteComponent the schemaNode points at. My first
plan was to create a hashtable of all given XSDConcreteComponents with
the Node as key. Is there a less time-consuiming way?
But there is another problem with these Nodes:
The XPaths point into an XMLSchema-File. Possible references in the
XMLSchema should be resolved. A Node pointing to a referred Element
should be translated into the resolved XSDConcreteComponent.
Example:
Schema:
<xs:complexType name="general">
<xs:choice minOccurs="0" maxOccurs="unbounded">
<xs:group ref="alpha"/>
<xs:group ref="beta"/>
<xs:group ref="gamma"/>
</xs:choice>
</xs:complexType>
<xs:complexType name="alpha">
</xs:complexType>
The context is the "general"-complexType-Element as XSDConcreteComponent.
The xpath is "/xs:choice/xs:group[1]".
The result-XSDConcreteComponent should be the resolved
"alpha"-complexType-Element.
Does someone has an idea how to implement such a method?
Thank you in advance
Hajo Hoffmann
| Re: Node -> XSDConcreteComponent [message #55787 is a reply to message #55758] |
Wed, 01 December 2004 08:34  |
--------------060403090002020701030205
Hajo,
You can use XSDSchema.getCorrespondingComponent to find the component
for a given node, e.g.,
context.getSchema().getCorrespondingComponent(schemaNode)
I don't think XPath will let you traverse resolved refs, so I don't
think you can do what you want with XPath in that regard.
Hajo Hoffmann wrote:
>Hi,
>Node.
> Example:
>Schema:
> </xs:choice>
> </xs:complexType>
> </xs:complexType>
> Hajo Hoffmann
<html>
<head>
</head>
Hajo,<br>
<br>
for a given node, e.g.,<br>
<blockquote> context.getSchema().getCorrespondingComponent(schemaNode)<br >
</blockquote>
think you can do what you want with XPath in that regard.<br>
<br>
<br>
<blockquote cite="midruninpanic-39ACE1.14202001122004@eclipse.org"
type="cite">
<pre wrap="">Hi,
Node.
Example:
Schema:
</xs:choice>
</xs:complexType>
</xs:complexType>
Hajo Hoffmann
</pre>
</blockquote>
<br>
</body>
</html>
--------------060403090002020701030205--
| Re: Node -> XSDConcreteComponent [message #592960 is a reply to message #55758] |
Hajo,
>Hi,
>Node.
> Example:
>Schema:
> </xs:choice>
> </xs:complexType>
> </xs:complexType>
> Hajo Hoffmann
<html>
<head>
</head>
Hajo,<br>
<br>
</blockquote>
<br>
<br>
type="cite">
<pre wrap="">Hi,
Node.
Example:
Schema:
</xs:choice>
</xs:complexType>
</xs:complexType>
Hajo Hoffmann
</pre>
</blockquote>
<br>
</body>
</html>
FUDForum. Page generated in 0.03193 seconds
