Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Unittests for java batch constraints
Unittests for java batch constraints [message #55757] Mon, 02 October 2006 13:57 Go to next message
Originally posted by: mystic77.gmx.net
I want to write some unit tests (Junit 4 or Junit 3.8) , which test the
behaviour of my implemented java batch constraints.
I want to test the validate method of my constraint class which is
derived from AbstractModelConstraint. I want t to test everything as a
plugin.
Is this possible ?
For any information on this I would be very pleased.
so thanks in advance
david
Re: Unittests for java batch constraints [message #55784 is a reply to message #55757] Mon, 02 October 2006 14:03 Go to previous messageGo to next message
David,
Given a GenModel, you can "Generate Test Code..." to generate much of
the scaffolding you'd need to set up a JUnit test suite. It should be
possible to extend this to also test your constraints.
david wrote:
> the behaviour of my implemented java batch constraints. I want to
> test the validate method of my constraint class which is derived from
> AbstractModelConstraint. I want t to test everything as a plugin. Is
> this possible ? For any information on this I would be very pleased.
> so thanks in advance david
Re: Unittests for java batch constraints [message #56219 is a reply to message #55757] Tue, 03 October 2006 17:40 Go to previous message
Hi, David,
Yes, this is possible. Have a look at how the
org.eclipse.emf.validation.tests plug-in tests the EMFT Validation
framework, itself, by performing batch validations and observing the
IStatuses that result.
For example, look in the
org.eclipse.emf.validation.internal.service.tests.ModelValid ationServiceTest
class's test_validateBatchSingle() method to see how it invokes validation,
extracts the IStatus results, and uses a convenient
assertAllConstraintsPresent() method to verify the execution of one or more
constraints.
HTH,
Christian
david wrote:
> plugin.
> Is this possible ?
> david
Re: Unittests for java batch constraints [message #593271 is a reply to message #55757] Mon, 02 October 2006 14:03 Go to previous message
David,
david wrote:
Re: Unittests for java batch constraints [message #593495 is a reply to message #55757] Tue, 03 October 2006 17:40 Go to previous message
Hi, David,
constraints.
HTH,
Christian
david wrote:
> plugin.
> Is this possible ?
> david
Previous Topic:programmatically parsing OCL constraints
Next Topic:Can I add my own class path entries to JETEmitter project
Current Time: Sat Nov 22 15:53:54 EST 2025
Powered by FUDForum. Page generated in 0.04199 seconds
