Home » Language IDEs » AspectJ » CompilationUnit from AspectJ source file?
CompilationUnit from AspectJ source file? [message #55754] Fri, 29 July 2005 10:00 Go to next message
Please, tell me wich part of ajdt plugin (Class, method) is responsible for
catching AspectJ file creation, producing ICompilationUnit from it and
adding CU to JavaModel?
I looked at org.eclipse.ajdt.internal.ui.wizards.NewAspectCreationWizard Page
but found only file creation there, so, I guess, CU creation is out there
and some another part is doing that job.
Sergey Gomanyuk.
junior research assistant, ISP RAS.
Re: CompilationUnit from AspectJ source file? [message #55781 is a reply to message #55754] Fri, 29 July 2005 11:19 Go to previous messageGo to next message
Hi Sergey,
Try org.eclipse.ajdt.core.javaelements.AJCompilationUnitManager.
Sian
> Sergey Gomanyuk.
Re: CompilationUnit from AspectJ source file? [message #59870 is a reply to message #55781] Tue, 27 December 2005 04:15 Go to previous message
Originally posted by: zifu.yang.gmail.com
Is there any simple way to add a ".aj" file into the a Java project /
AspectJ Project?
A more general question is how to simply add any file into a Java project?
Of course we can refer to the WizardCreation code, but any simple way?
AJCompilationUnitManager is used for those files already in the projects. So
I need
to add the files into project first.
If it is a java file, I can easily create some compilationUnit under some
package fragment.
But for ".aj" file, it is harder.
"Sian January" <sjanuary@uk.ibm.com> wrote in message
news:dcdhdu$575$1@news.eclipse.org...
> Hi Sergey,
> Sian
>> for catching AspectJ file creation, producing ICompilationUnit from it
>> and adding CU to JavaModel?
>> I looked at
>> org.eclipse.ajdt.internal.ui.wizards.NewAspectCreationWizard Page but
>> found only file creation there, so, I guess, CU creation is out there and
>> Sergey Gomanyuk.
Re: CompilationUnit from AspectJ source file? [message #589753 is a reply to message #55754] Fri, 29 July 2005 11:19 Go to previous message
Hi Sergey,
Sian
> Sergey Gomanyuk.
Re: CompilationUnit from AspectJ source file? [message #591487 is a reply to message #55781] Tue, 27 December 2005 04:15 Go to previous message
AspectJ Project?
I need
package fragment.
> Hi Sergey,
> Sian
>> I looked at
>> Sergey Gomanyuk.
Previous Topic:Fighting AJDT
Next Topic:ajdt not executing advice when the aspect is included in a large project
Current Time: Fri Oct 31 04:17:49 EDT 2025
Powered by FUDForum. Page generated in 0.03098 seconds
