Unloading classes when app running [message #55744] |
Fri, 30 May 2003 06:47  |
Originally posted by: pdrolet.mac.com
Posted with an Unregistered Version of NewsHunter - The Newsgroup Utility for OS X.
Get your copy today at: http://www.parkersoftware.com/products/newshunter/
The time it takes for a development cycle is critical for a developer. Even though Eclipse is not bad compared to other development environment, I am looking at ways to improve it.
Here is the problem: I use a prevayler database in a plugin. The database is about 6 megs (I cannot really make it simpler - I need the data to test the plugin). Each time I want to test a new function or a modified code, this data need to be reloaded (I use "run-time workbench" using another eclipse directory - only the platform's plugins).
I read somewhere that it is possible to unload and reload a class or a library in real time. Is it possible to do it with Eclipse in a run-time workbench?
Patrice Drolet
FUDForum. Page generated in 0.07342 seconds
