Home » Eclipse Projects » DTP » generate entities problem with sql server
generate entities problem with sql server [message #55739] Fri, 17 April 2009 11:12 Go to next message
Hi, when I generate entities against a SQL Server 2005 database, entity
relationships are not being generated. Foreign key constraints are defined
for the database.
I've shown a constraint definition below which I got from Microsoft SQL
Server Management Studio. Any help is appreciated - Ted
ALTER TABLE [dbo].[ALL_EQUIPMENT] WITH NOCHECK ADD CONSTRAINT
[FK_EQUIPMENT_SUM_AFFILIATION] FOREIGN KEY([AFFILIATION])
REFERENCES [dbo].[L_AFFILIATION] ([AFFILIATION_CODE])
NOT FOR REPLICATION
Re: generate entities problem with sql server [message #55798 is a reply to message #55739] Fri, 17 April 2009 19:00 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
What version of DTP are you using? The MSSQL support has improved in our
Galileo (1.7) work that's due out in June 2009. That may solve the issue.
--Fitz
"ted beckett" <work.beckett@gmail.com> wrote in message
news:9ddd69bc09a6796cf87835c317f97191$1@www.eclipse.org...
> for the database.
> NOT FOR REPLICATION
Re: generate entities problem with sql server [message #55853 is a reply to message #55798] Mon, 20 April 2009 10:59 Go to previous message
I'm using version 1.6.2.
I've learned more since my first post. Originally I only selected a single
table in the Generate Entity dialog and expected it to generate classes
for each related table. Now I think that is not how it works (my mistake).
If you want to generate classes that are related you must select the
related tables in the entity generation wizard.
When I select a set of related tables I get the error below. I've seen
postings/bug reports on this so I have more investigation on my own to do.
Thanks very much for your response.
An internal error occurred during: "Generating Entities".
ALL_FACILITY.FK_ALL_FACILITY_SUM - mismatched sizes: 0 vs. 1
Re: generate entities problem with sql server [message #595582 is a reply to message #55739] Fri, 17 April 2009 19:00 Go to previous message
--Fitz
> for the database.
> NOT FOR REPLICATION
Re: generate entities problem with sql server [message #595594 is a reply to message #55798] Mon, 20 April 2009 10:59 Go to previous message
Previous Topic:MySql connection through unix socket
Next Topic:Map files for milestone releases
Current Time: Fri Nov 21 07:00:43 EST 2025
Powered by FUDForum. Page generated in 0.04552 seconds
