Home » Eclipse Projects » Remote Application Platform (RAP) » Servlet delegate not registered
Servlet delegate not registered [message #55709] Fri, 26 October 2007 06:10 Go to next message
i've deployed my app under Tomcat. All seems to loads correctly but when i
invoke the url http://localhost:9080/test/sp_test
the answer is Servlet delegate not registered.
below some informations
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.3.0.v20070530
Fragments=36
1 ACTIVE javax.servlet_1.0.0.200710261152
2 ACTIVE org.eclipse.core.commands_3.3.0.I20070605-0010
3 ACTIVE org.eclipse.core.contenttype_3.2.100.v20070319
4 ACTIVE org.eclipse.core.expressions_3.3.0.v20070606-0010
5 ACTIVE org.eclipse.core.jobs_3.3.0.v20070423
6 ACTIVE
org.eclipse.core.runtime.compatibility.auth_3.2.100.v2007050
2
7 ACTIVE org.eclipse.core.runtime_3.3.100.v20070530
8 ACTIVE org.eclipse.equinox.app_1.0.0.v20070606
9 ACTIVE org.eclipse.equinox.common_3.3.0.v20070426
10 ACTIVE org.eclipse.equinox.http.registry_1.0.0.200710261152
11 ACTIVE
org.eclipse.equinox.http.servletbridge_1.0.0.200710261152
12 ACTIVE org.eclipse.equinox.http.servlet_1.0.0.200710261152
13 ACTIVE org.eclipse.equinox.preferences_3.2.100.v20070522
14 ACTIVE org.eclipse.equinox.registry_3.3.0.v20070522
15 ACTIVE org.eclipse.equinox.servletbridge_1.0.0.200710261152
16 ACTIVE org.eclipse.osgi.services_3.1.200.v20070605
17 ACTIVE org.eclipse.rap.jface_1.0.0.20071010-2241
18 ACTIVE org.eclipse.rap.rwt_1.0.0.20071010-2241
19 ACTIVE org.eclipse.rap.ui.workbench_1.0.0.20071010-2241
20 ACTIVE org.eclipse.rap.ui_1.0.0.20071010-2241
21 ACTIVE org.eclipse.update.configurator_3.2.2.R32x_v20070111
36 RESOLVED org.eclipse.equinox.servletbridge.extensionbundle_1.0.0
Master=0
in the folder work\Catalina\localhost\test\eclipse\configuration there is
no log file...so there is no error....
What's wrong?
Christian
Re: Servlet delegate not registered [message #55763 is a reply to message #55709] Fri, 26 October 2007 06:57 Go to previous messageGo to next message
sorry...this is the correct log from equinox...
osgi> ss
id State Bundle
Fragments=37
1 ACTIVE javax.servlet_1.0.0.200710261234
6 ACTIVE
2
10 ACTIVE org.eclipse.equinox.http.registry_1.0.0.200710261234
11 ACTIVE
org.eclipse.equinox.http.servletbridge_1.0.0.200710261234
12 ACTIVE org.eclipse.equinox.http.servlet_1.0.0.200710261234
15 ACTIVE org.eclipse.equinox.servletbridge_1.0.0.200710261234
22 ACTIVE test_1.0.0
37 RESOLVED org.eclipse.equinox.servletbridge.extensionbundle_1.0.0
Master=0
Help me! :)
Christian
christian ha scritto:
> i invoke the url http://localhost:9080/test/sp_test the answer is
> osgi> ss
> id State Bundle
> Fragments=36
> 6 ACTIVE
> 2
> 11 ACTIVE
> Master=0
> is no log file...so there is no error....
> What's wrong?
> Thanks
> Christian
Re: Servlet delegate not registered [message #57522 is a reply to message #55763] Mon, 05 November 2007 04:27 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
seems as if all necessary bundles have been activated. Are you sure that you
have set the init-param enableFrameworkControls in the web.xml? The RAP
deployment demo contains a web.xml that has that setting commented out.
Because of this the sp_test doesn't work with RAP deployments by default.
For log information you may look at
work\Catalina\localhost\test\eclipse\workspace\.metadata\.lo g
Hope that helps!
Ciao
Frank
"Christian" <zerostress@libero.it> schrieb im Newsbeitrag
news:ffsh7h$5oo$1@build.eclipse.org...
> osgi> ss
> id State Bundle
> Fragments=37
> 6 ACTIVE
> 2
> 11 ACTIVE
> 37 RESOLVED
> Master=0
> Help me! :)
> Christian
>> osgi> ss
>> id State Bundle
>> Fragments=36
>> 6 ACTIVE
>> 2
>> 11 ACTIVE
>> 36 RESOLVED
>> Master=0
>> What's wrong?
>> Thanks
>> Christian
Re: Servlet delegate not registered [message #78774 is a reply to message #55709] Thu, 20 March 2008 09:11 Go to previous message
Hoping that someone other will learn from my mistakes...
The same error message ocurrs if the javax.servlet plugin is deployed
within the war file. This is not necessary, as tomcat provides it as a
lib from outside.
Stefan.
christian schrieb:
> osgi> ss
> id State Bundle
> Fragments=36
> 6 ACTIVE
> 2
> 11 ACTIVE
> Master=0
> What's wrong?
> Thanks
> Christian
Previous Topic:Problem with Tomcat 6 & RAP 1.0
Next Topic:problem with custom widget
Current Time: Sat Nov 08 08:50:57 EST 2025
Powered by FUDForum. Page generated in 0.03098 seconds
