Home » Newcomers » Newcomers » JRE Difficulties
JRE Difficulties [message #55679] Wed, 20 April 2005 13:38
Originally posted by: cimmerian76.hotmail.com
As brand new user of Eclipse 3.0.2 I have been working through the tutorial
exercises from JDG2E. In the second exercise from the tutorial about quick
fix I reach a point where I am supposed to run a .jpage on some example code
that I fixed. However, instead of a successful operation, the debugger
kicks on. Its main theme is that for several methods called "The .jar file
rt.jar has no source attachment" (JRE 1.4.2_08) or alternatively, "The
source attachment (which is set as src.zip in my J2SDK dir) does not contain
the source for the file ****.class" (with J2SDK 1.4.2_08's included JRE).
For either JRE's (I know they are essentially the same, or at least are
supposed to be) the classpath key JRE_SRC is set "correctly" as far as I can
tell. I've also looked through the JRE directories on my file system, but
at this point I really don't know what I'm looking for.
Is this a common problem with Sun's JDK and JREs? I also tried 1.4.2_03
JRE.
Previous Topic:Main-Class manifest is missing?
Next Topic:Downloading CppUnit plugin
Current Time: Mon Nov 17 12:10:00 EST 2025
Powered by FUDForum. Page generated in 0.07734 seconds
