Home » Eclipse Projects » GEF » Make Label to have several editable parts?
Make Label to have several editable parts? [message #55655] Fri, 17 January 2003 14:31 Go to next message
Couple months ago I post a message about how to make label to have several
editable parts. Randy Hudson, that can be done if a simple change is made in
GEF. Would you please tell me if that change is in the latest build?
Thank you.
Subject: Re: Make Label to have serval editable parts?
Newsgroups: eclipse.tools.gef
Organization: EclipseCorner
Date: Oct 09 2002 20:24:13
If we make a simple change in GEF (SelectEditPartTracker), Hal could use
this figure with a single editpart. The change would be to make "direct
edit" a LocationRequest. Hal could just take the Request and compare its
location to the location of the 3 labels.
However, both of these solution only work with the mouse. You would still
have to figure out how to switch between the 3 CellEditors with the
keyboard.
> > public void performRequest(Request request) {
> > if (request.getType() == RequestConstants.REQ_DIRECT_EDIT) {
Point where = ((LocationRequest)request).getLocation(); //Returns the
location on the Canvas
getMonthLabel().translateToRelative(where); //You could use any of the
3 labels for this translation
if (getMonthLabel().containsPoint(where)){
performMonthDirectEdit();
} else if ...
//etc.
Re: Make Label to have several editable parts? [message #55688 is a reply to message #55655] Fri, 17 January 2003 15:17 Go to previous messageGo to next message
Yes, DirectEditRequest is now a subclass of LocationRequest.
Eric
Hal wrote:
> Thank you.
> From: hudsonr@us.eye-bee-em.com (Randy Hudson)
> keyboard.
> } else if ...
> //etc.
Re: Make Label to have several editable parts? [message #56008 is a reply to message #55688] Sat, 18 January 2003 14:20 Go to previous message
Thanks. I try this, but the getLocation() always return me the *SAME*
co-ordinate regardless where I click on the label.
Here is what I did:
- create a new LocationEditManager and in its createDirectEditRequest(),
copy the location from the incoming directEditRequest to this new Direct
edit request that it is going to create.
protected DirectEditRequest createDirectEditRequest(){
DirectEditRequest req = new DirectEditRequest();
if (request != null){
req.setLocation(incomingDirectEditRequest.getLocation());
req.setCellEditor(getCellEditor());
return req;
- create a new DirectEditPolicy, I print out the location of the request:
But the location is ALWAYS the same, regardless where I click the label:
protected void showCurrentEditValue(DirectEditRequest request) {
System.out.println ("showCurrentEditValue x:" + request.getLocation().x + "
y:" + request.getLocation().y);
LogicSubpart host =
(LogicSubpart)((AbstractGraphicalEditPart)getHost()).getMode l();
- in my editPart, I install this new direct edit policy and create my new
directEditManager when necessary.
Could you please if I miss anything? What I want to do is I have a label
looks like this "XX / MM / YY", if user clicks between the beginning of the
label to the first "/", I only pops up "XX". Same thing if user clicks
between the first "/" and the last "/", only "MM" will pop up.
Thanks for any help.
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:b09ncg$hvk$1@rogue.oti.com...
> Eric
> Hal wrote:
> > Hi,
several
made in
> > Thank you.
its
still
> > keyboard.
the
the
> > } else if ...
> > //etc.
Previous Topic:graph?
Next Topic:selection in I20030116
Current Time: Sat Jul 26 14:42:29 EDT 2025
Powered by FUDForum. Page generated in 0.03154 seconds
